Can anyone recommend another audio CD burner. My Nero has now decided to skip, and I got tired of trying to find a solution. I use Cheetah with no problems except that It does not allow you to remove the spaces between tracks on a live CD to give one seamless track.
Any suggestions?
Roxio is pretty good
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
RecordNow is usually recommended.
What speed are you burning at? As sketchy as Nero can be for DVD, I've never had issues with it as an audio burner (I use 6.6.something) -
In Nero, if you select all but the first track & go to Properties, you can make the pause btw tracks 0 seconds for seemless play (unless your ripper adds seconds to the mp3s.)
I have 40x burner, but have dropped down to the lowest burn rate with the same problem.Originally Posted by Jester700
Strange thing is, that I can burn 20 CDs of the same album, and the skips are in excactly the same place every time.
But Nero will burn my DVDs perfectly.
Any Ideas? -
CD Burner XP Pro
/Mats
Alternatives to Toast
By danielmak in forum MacReplies: 6Last Post: 17th May 2010, 00:37 -
Alternatives to Rapidshare ?!
By Delta2 in forum ComputerReplies: 15Last Post: 3rd Dec 2009, 18:51 -
Alternatives to YouTube
By Karel Bata in forum Video Streaming DownloadingReplies: 1Last Post: 16th Jul 2009, 14:52 -
Alternatives to ripit4me
By 123fish123 in forum Newbie / General discussionsReplies: 31Last Post: 7th Mar 2009, 14:43 -
Please recommend any good Nero alternatives for Vista
By driguy in forum ComputerReplies: 1Last Post: 17th Feb 2008, 15:51
