  1. I am having some problems playing newer AVI files. They say that I need the 4.02 codec which I have, but I only end up w/ blank screen in Windows media player. The codec player says its in incorrect file type. Also, when I check the file details there is no audio, just video.
  2. go to http://www.divx-digest.com and you'll find all the codecs and filters there. try installing some of the codec packs like nimo or tsunami
    Dec 2001
    Australia
    i'm having the same problem with a movie file i downloaded.
    it says i need 4.02 and there is no movie or sound..
    if you find out how give me an email kris@toughguy.net
    Dec 2001
    I had problems with new files to, I downloaded the ace mega codec pack and now it all works fine.
    http://www.divx-digest.com/software/acemega_codec.html
    But it has an hungarian language file, so click the right button when if it ask you to overwrite.
    /Jari
    Jari Bilén
    jarizappa@hotmail.com
  5. I installed just about every codec on that site, still no dice.
