hi!
i have the following problem with ffmpegx (0.0.9u):
after encoding all my videos into h.264 (nomatter what kind of source i use) they have a green line at their bottom (about 10 px height). does anyone know what i'm doing wrong?
thanks
bender06
Hi bender06,
You might not be doing anything wrong - depending on the source, there might be some "messy" video at the bottom of your footage. I have a DV cam that has a few lines of noise at the top of the footage.
Your encoder might pick up on this and translate it to the green line that you see after encoding. If the final product is for TV, don't worry about it as there's a very good chance it'll be covered by the overscan area of your TV screen (that's the area of the screen that's covered by the seal that hold's the tube in).
I don't know if the same applies to a HDTV.
You are best playing it on what you will be watching the final footage on (PC monitor, TV, HDTV) and see if you can see it / if it bothers you.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
How can I show subtitles on the the top line and on the bottom line.
By Dracko in forum Authoring (DVD)Replies: 14Last Post: 8th May 2014, 15:03 -
Green Bar at bottom problem solved!
By DeniseAck in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2011, 19:19 -
green line at bottom of video window
By miniboss91 in forum Video ConversionReplies: 3Last Post: 11th Jan 2010, 21:51 -
There is a narrow line at the bottom of my screen.....
By gom in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 12:16 -
Horizontal Line near bottom of video
By tdelarosa in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2007, 15:09
