    Dec 2005
    Did you see my problem? i have the files in the video_ts folder and it doesnt play on standalone dvd player, but plays on comp....
    What does author means? If authoer means putting them in Video_ts , i did that with dvd shrinker...( i didnt use reauthoer mode, i just use full backupmode)
    USA
    Playing in a computer doesn't mean a lot. My computer will play bad and corrupted files that won't work on a standalone player.
    Have you sucessfully backed up a DVD from a commercial disc before using DVD Shrink and Nero?
    If not, problems with the media you are using would be my first guess.
    Dec 2005
    my friend said my file is not decrypted and it wont work on dvd player...is that true? ifs thats true, i just use dvd decrypter?
  4. Mod Neophyte redwudz's Avatar
    USA
    Please don't threadjack. You problem is not the same as the original poster. I have created a new post and moved this discussion to it.
    And please use this or the other thread you started and don't post the same question in both.
