I have a few DVD-RW VR recordings made on my Pioneer 220 and I would like to convert them to a standard DVD-R. I thought I could simply finalize the DVD-RW and use Nero to copy it, but Nero says there is not enough space on the destinatin DVD (it is a blank DVD-R but Nero claims it is short a few megabytes).
I also tried DVD Shrink and DVD Decryptor and they don't recognize the VR mode format so they won't open the files on the VR disk.
Am I stuck with the information on these disks? Or is there a way to copy it to a DVD-R?
Also can I erase these disks and reformat them to a normal Video Mode disk?
TIA
Brent
When I first got a Pioneer 420 I made the mistake of doing some VR mode recordings (I only use DVD-RW's in video mode now). I was able to re-author them to a standard DVD-R using Tmpeg DVD Author - just selected "Add DVD-Video" and it recognised and imported the titles no problem. I'm sure there are other apps that will let you do this, but I haven't tried any.
There will be no problem in erasing the discs and using them in Video mode in the future. When you're ready, just select Initialize from the Disc Setup part of the Home Menu. Make sure you choose Video mode and you're sorted! -
The software costs $59 which is a lot to pay just to get these disks copied.I was able to re-author them to a standard DVD-R using Tmpeg DVD Author
Is there anything out there cheaper? TIA
Brent -
Sorry, I had to go see about a girl
You can get the 30-day trial version of TMPG DVD Author for free here:Originally Posted by Brent G.
http://www.pegasys-inc.com/en/download/tda16.html
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 19:16 -
cannot copy files to computer or copy dvd
By moshik16 in forum Newbie / General discussionsReplies: 0Last Post: 14th Feb 2010, 17:09 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
DVD Player Compatible with 2004 Pioneer DVR 220-S VR Mode of Recording
By iloveamerica11 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Dec 2007, 12:14
