Closed Thread
Page 2 of 2
FirstFirst 1 2
Results 31 to 36 of 36
    Dec 2005
    okay, its pal...what do i do next?
    May 2004
    Sorry to jump in here late. I tried to back up SpiderMan2 Special Collectors Ed. and the ripped vobs were about 1.23G like you described earlier. Sony had put all the subtitles in each vob and when ripped they were unplayable.
    Well, they played, but the language was different for each vob and one had the sound from an extra feature on the right channel with the correct left channel for that vob.
    Try to play the vob's first. If that works then ifoedit should work just fine.
    May 2003
    if ur player wont play pal dvd's then you will need to convert it to ntsc ... this is not an easy job .. do a search on the guides section for 'pal to ntsc conversion' for ways of doing this .... you'll find more help there than i could give you as i live in uk and pal is the standard here so i have never had to convert to ntsc
  4. OK Jesse the program that I use to convert PAL to NTSC is DivxToDVD from VSO software very good program.
  5. Banned
    Feb 2005
    USA
    Why not just re-rip the entire video contents again? That would be much easier then all this rigamoroll.
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Because he Downloaded it
    https://forum.videohelp.com/viewtopic.php?p=1431743#1431743
