Hi, I have a gigabyte GA-7N400 pro M/B with a AMD 1800 CPU.
Can anyone tell me if it will take a AMD 2800 ? or a 3000?
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
It says yes.
http://www.giga-byte.com/Motherboard/Support/CPUSupportList/CPUSupportList_GA-7N400%20Pro2%20(Rev%201.x).htm -
Many thanks, and Merry Christmas
Should I re-upgrade from Asus/AMD to Gigabyte/Intel?
By Stealth3si in forum ComputerReplies: 23Last Post: 16th Apr 2012, 21:06 -
Can't get audio in to work on Gigabyte GA-EP35-DS3P
By DarrellS in forum ComputerReplies: 8Last Post: 25th May 2008, 05:49 -
GIGABYTE motherboard / Intel Pentium D 935
By thebirdf in forum ComputerReplies: 4Last Post: 2nd Nov 2007, 14:50 -
Shall it be mobo Asus or Gigabyte
By RabidDog in forum ComputerReplies: 13Last Post: 20th Sep 2007, 06:43 -
Gigabyte GA-G33M-DS2R
By wulf109 in forum ComputerReplies: 2Last Post: 10th Aug 2007, 09:16
