I am dropping 60% plus frames during capture from my 8mm videocam using Virtual Dub.
I run a WinTVGo card on a 733 MHz CPU 128MB RAM to a dedicated slave 40GB hard drive all under WinXP.
One change I made that seemed to coincide with the problem was that I changed my primary 30GB drive from FAT32 to NTFS in order to beat the 4GB file size.
I have tried all the usual suspects-defrag, clean player heads.
Note that the frames drop even when there is no input signal, ie capturing "blue screen"
check UDMA mode for that hard drive first whether it is set.
and you didn't say what resolution you capture at and what codec you use... -
Make sure that your hard drive is not set to compress data on the fly. It is an option when formatting to NTFS. To check right-click on the hard drive in "My Computer" and go to properties. Towards the bottom of the window will be an option to compress the hard drive. Make sure this is unchecked.
<font size=-1>[ This Message was edited by: DSquare on 2001-12-27 09:52:27 ]</font> -
Did you try the AuxSetUp that comes with VirtualDub? What KB/s does your Hard drive show?
What is your CPU usage on VirtualDub? Try capturing uncompressed if CPU load is high.
Since you mention that this problem exists at any resolution, It could be a problem with your Capture card drivers. Check if you can get a latest version.
I may not be able to help you more than this. -
I was dropping many frames (at any resolution) with my WinTV card due to audio/video synchronization. Try to capture without sound and see if the problem persists.
Do you have a mobo with a via chipset (ie: a7v133) if you do you should try the newest 4 in one drivers. I have problems with frames being droped then remembered that i still had yet to install them, as soon as i did, the loss of frames when away...
If the Apocalypse comes...Beep Me - Buffy
AverMedia HD DVR - Frame drops in live playback
By Anonanon in forum Capturing and VCRReplies: 3Last Post: 1st Mar 2012, 02:11 -
Subtitle massive shifting
By zibizibi in forum SubtitleReplies: 5Last Post: 12th Jul 2011, 07:32 -
Massive conversion operation
By NickPapageorgio in forum Video ConversionReplies: 1Last Post: 28th Jun 2011, 15:36 -
Joining 2 TS streams produce glitch and frame drops
By arminio in forum DVB / IPTVReplies: 8Last Post: 7th Jun 2011, 03:30 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26
