Will my old video editing software (Sonic Foundry Vegas 4.0 + DVD) still work if I upgrade my system to a AMD Athlon64 3800 processor?
Yes, you're still just using Windows afterall.
FB-DIMM are the real cause of global warming -
64 bit processors are backwards compatiable, they run 32bit apps also
I just don't suggest Windows 64 at this time. Stick with standard XP. Otherwise everything should be fine.
Here's one Windows X64 OS compatibility guide:
http://www.3dvelocity.com/articles/win64compatibility/win64softlist.htm
I have X64 on one of my computers and I see no real advantage to it presently over XP Pro or Home. (32bit) I'm thinking there will be as more XP64 aware programs become available.
But if you just have a 64bit CPU, you can run XP32 on it now with no compatibility problems. It doesn't require a 64 bit OS.
Generally, I'd wait for XP64 to mature a little, along with the availability of more native X64 programs before I would make the change in OS's. -
64-bit processors will run 32-bit code just as fast (if not faster still) than 32-bit only processors. They can just handle 64-bit systems and applications too.
As for Windows 64-bit Edition, I wouldn't bother. There isn't really much of an advantage to running that (aside from the knowledge that it's a true 64-bit system). Wait until Longhorn comes out - maybe (don't quote me on this) they will need to be re-writing software and drivers for that. They should release a 64-bit flavour of it, and that's when I'm going to make the jump. Windows XP is a bit long in the tooth to be making steps like this, methinks. -
It goes beyond that. I can think of some DISadvantages to running XP 64-bit at this point. I'd stay clear away from it. Like cobra said Wait for Windows Vista. (longhorn to those stuck in the 3 months ago
Sorry - I meant Vista!
(thanks Faustus!)
A Media Player That Actually Works On A 64 Bit System
By JayLovesKasesSky in forum Software PlayingReplies: 24Last Post: 5th Oct 2013, 07:06 -
32 bit software compatibility with 64 bit machine ?
By joecass in forum ComputerReplies: 6Last Post: 28th Aug 2011, 09:09 -
Working with Subtitles on a 64-Bit System: XVid, SUPER, & Virtual Dub
By jdanniel in forum SubtitleReplies: 17Last Post: 22nd May 2010, 13:08 -
I have a 64bit system, to encode files do i need 64 bit codecs?
By shadowofanubis6 in forum Newbie / General discussionsReplies: 5Last Post: 1st Mar 2010, 10:24 -
Calibration of an 8 bit digital component editing system using color bar.
By edDV in forum Video ConversionReplies: 4Last Post: 20th Feb 2008, 12:48
