Is it possible to capture video in mpeg for mat. I use Ulead Media Studio Pro 6.0 to capture and it says I can only capture in avi. How can I capture in mpeg ?
Results 1 to 10 of 10
Under MediaStusio---capture settings, select either "Uleald VFW MPEG capture driver" or "Ulead DirectShow MPEG driver" depending upon the capture driver you installed. Then you should be able to capture in MPEG format.
I tried that and I get some error saying my drivers don't support it. How can I get driver that support mepeg capture ?
Your capture driver have to support YUV or RGB capture format, MPEG part will be take care of by MediaStudio.
If you list your capture hardware and driver detail, somebody else has a similar set up may help you out. -
I’m not sure of the exact brand name buts its list under device manager as PCI OHCI Compliant IEEE 1394 Host Controller.
If that is the only capture card you have, you pretty much out of lucky.
IEEE 1394 is a firewire card, most likely, it only capture to DV AVI.
There does exist a few programs that can capture MPEG from 1394 card, such as InterVideo Wincoder. -
AT,
I'm using a 1394 capture card and ASUS 3800 video card which comes with video capture feature. The software is Ulead Studio 5.0. Can I capture in MPEG1/2 format? My system is; 700 Duron, 128M, 20G/ATA100. Thanks a lot. -
"...and ASUS 3800 video card which comes with video capture feature"
Possiblly. In VideoStudio 5, switch video capture driver to either VFW MPEG capture driver or DirectShow MPEG capture driver (whichever works).
Set Video format to NTSC/PAL 352X240/288 for VCD or 480X480/576 for SVCD, if your ASUS 3800 support the size.
Within Video compressing settings, chose MPEG, you'll see a Ligos Gomotion set up screen, select the same fram size as you original (otherwise it won't capture). Set bitrate, audio etc. up, and you are ready to go.
PS: If you ASUS 3800 can capture in YUV or RGB format, it will be almost certain that you can capture MPEG in real time with MediaStudio Pro or VideoStudio.
Many other program also might work for you to capture to MPEG in real time, such as Power VCR, WinVCR, and Wincoder etc. A few will also let you capture MPEG in real time through firewire (IEEE 1394) port.
<font size=-1>[ This Message was edited by: AT on 2001-07-18 18:18:22 ]</font>
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Video mepeg merging/combining
By rbrass1981 in forum EditingReplies: 2Last Post: 11th Dec 2009, 08:03 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
