Hi all!
I have agreed to capture all my friends and families old VHS/SVHS to DVD, and I have search the forum for answers...
I have decided to go for these 2 converters, the Canopus ADVC-110 AV-converter or the Miglia Director´s Cut Take 2 we will see which the shop has on it's shelves..
But which VHS player should I buy??? used or a brand new one??
I have found 2 used but are they any good???
JVC HR-S7722EU
Samsung SV4000W
Could you come with some new brands and which models to buy??
Thx, hope you can help...
Results 1 to 11 of 11
You may find this interesting...
https://forum.videohelp.com/viewtopic.php?t=287476 -
You will live to regret those words.Originally Posted by haribo
Thx davideck...
Have looked at the link, and searched for some of the players..
Iam from Denmark (Europe), and can't find the models....Are those US models???
Have also found this Super VHS, Panasonic NV-FS88 HQ
But all the models have different numbers...??
HELP...
To: Captain Satellite
Hopefully I will live, but it's a lot of work YES.... -
I would recommend a Super VHS VCR over a standard VHS VCR.
The link I provided did reference US Models.
The JVC HR-S7722EU looks to be similar to the HR-S9600U.
The Panasonic NV-FS88 HQ looks good too, although it may not have a TBC/DNR system? -
So Davideck
Which of these would you go for....they are all used and have added the price..
JVC HR-S7722EU - 80$ - has only been used as Tuner in a home cinema system, so drive is not been used...he says....
Panasonic NV-FS88 HQ - 175$
Panasonic NV HS1000 (Digital TBC) - 475$
And found this one
Super VHS, JVC Hr-D8500 - 636$
Hope Iam not bothering you too much with my questions...
But will I get a much better picture with some of the other models, or will the final result be nearly the same??
How much difference will the final result be with Digital TBC is it worth all the extra money.. -
The 7722 should be similar to the 7600. It's a "foreign model" so I've never used one personally.
Yes, a TBC is worth the money. It should have other audio and video filters too.Want my help? Ask here! (not via PM!)
The HR-S7722EU has (digital) TBC/DNR, right? That's what makes it such a great value.Originally Posted by haribo
I think that "nearly the same" is in the eye of the beholder.
Your results will depend upon the condition of your tapes, and you may eventually need a more expensive VCR for tapes that are problematic (as in the link that I referenced above). Even so, for $80, I would start with the HR-S7722EU and go from there.
I have several VCRs that I use for capturing. Sometimes a certain tape will just play better in one VCR than in another.
https://forum.videohelp.com/viewtopic.php?t=280739 -
OK thx I will contact him tomorrow...And buy the
HR-S7722EU
Do you know anything about the Canopus ADVC-110 AV-converter or the Miglia Director´s Cut Take 2??
Do they both deliver the goods...
Done capturing my VHS, what now?
By Akerhage in forum Video ConversionReplies: 31Last Post: 27th Jul 2011, 08:37 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 16:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 09:32 -
capturing vhs video
By DV VIRGIN in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 08:26 -
capturing video from a vhs videotape player to PC
By kasfig in forum Capturing and VCRReplies: 7Last Post: 10th Mar 2008, 09:19
