hi i downloads a movie the file is in 2 cd.how i burn this 2 files in one disk to view in my dvd.thanks
It depends on the format of the file. If it's VCD, then you can use a program like TMPGEnc DVD Author. It will convert the sound to DVD compliant 48Kz audio and the file to DVD compliant video format for burning to DVD. If it's SVCD, then SVCD2DVD is a good all-in-one converter program to convert to DVD. There are many other methods.
I usually first drop a video file into a program like Gspot or AVIcodec to tell me what format the file is. If your final destination is DVD, then study 'What is' DVD to the left. <<<< That will tell you about the DVD format that you will have to adhere to. Then you look to 'Convert', again to the left, to look at some guides to help you do the conversion.
And any time you post or reply here, you need to adhere to the AUP that is at the top of the page when you post.
Above all, do some reading. We are more than happy to assist newcomers, but we expect you to become informed as much as possible before you ask.
If the movie is available to buy on DVD, you should buy it. If it is on "2 cd", more than likely the quality is total crap.
DvdRip downloads?
By Takeonelastbreath in forum Newbie / General discussionsReplies: 9Last Post: 20th Sep 2010, 15:16 -
legal downloads
By Mr anderson in forum Off topicReplies: 3Last Post: 13th Jun 2008, 23:28 -
torrent downloads
By efiste2 in forum AudioReplies: 11Last Post: 17th Oct 2007, 01:28 -
codec downloads
By Noek in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 13:26
