I decrypted the only the movie files, but when I open up the dvd shrink to re-author the files, all thats listed is the menu. There is no main movie. I have shrunk many movies before using the same process. How do I go about getting the main movie files so I can add them and then back them up?
What did you use to decrypt the files? With programs like DVDDecrypter, you need to decrypt the whole DVD. Then use Shrink to sort out what you want for your final DVD.
I used DVDDecrypter to decrypter the movie. I used the same process on many movies...I did see tat others on the forum are having the same problem...The movie I am having trouble with is The Brothers Grimm. The main movie just wont appear in the re-author list.
That's a problem movie to back up, apparently. Read here:
https://forum.videohelp.com/viewtopic.php?t=287807
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
About to author, what BG Music
By nirbhayn in forum Authoring (DVD)Replies: 4Last Post: 20th Aug 2009, 22:14 -
how to author a CD?
By michcio in forum Authoring (VCD/SVCD)Replies: 4Last Post: 2nd Sep 2008, 14:06 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
seems to author twice
By BroomQueen in forum Authoring (DVD)Replies: 7Last Post: 15th Oct 2007, 09:22
