purchased a previously viewed dvd from block buster. i want to burn a backup but the dvd burner doesn't recognize the dvd. my dvd player has no problem reading the dvd. the burner can read any dvd i put in it but this blockbuster dvd. how do i get the burner to recognize this dvd
thanks
greg
Results 1 to 10 of 10
First - What is the title of the DVD in question?
Second - Since it's a previous rental, take a good look at the surface for scratches.
Your next step will depend on the specifc title and whether the disk is scratched.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
the name of the movie is white chikc and there are some scratches towards the center of the dvd
thanks
greg -
sounds like its probably the disc itself then.....either you can take it back and try and get em to swap it for a differant one or else take it somewhere to get it resurfaced......if your dvd burner can't read it, its not very likely that your dvd player will read it correctly, either....
if the disc is scratched using iso buster would not help if he can't rip the disc to begin with. i suspect his dvdrom/dvdburner is not able to read discs that are scratched. try using the disc in someone elses computer. plextor dvdrw, benq 1620 & 1640 dvdrw's are known to read scratched discs.
my bad, the part where he said "doesn't recognize the dvd" just totally didn't register when I read it....
What We Do In Life, Echoes In Eternity.... -
you been drinking too much eggnog eh!!!Originally Posted by Denvers Dawgs
ahhh.....good old eggnog, tis the season
White Chicks has no unusual copy protection. Since the scratches are at the center of the disc, and discs play from the center out, that's the likely cause of your problem. Blockbuster has a thirty day replacement policy on defective DVD's - take advantage of it.
--Benjamin Franklin
DVD player doesn't recognize XVID files
By Theodorist in forum DVD & Blu-ray PlayersReplies: 11Last Post: 18th Jan 2010, 00:42 -
Burner Won't Recognize Blank DVD-R Discs
By ddowden1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Aug 2009, 07:52 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 07:16 -
Suddenly, burner doesn't recognize blank DVD
By slats7 in forum ComputerReplies: 9Last Post: 13th May 2008, 12:10 -
Ulead DVD MovieFactory 6 - Doesn't recognize DVD
By urlilgurl017 in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2007, 13:52
