Hello,
I created a standard SVCD (Video-2200Kbps,Audio-224Kbps) from a verh high quality VHS tape. The SVCD it quite good ....video looks great and the audio sounds great, no problems there.
However, the audio and video are not in sync after I fast forward or rewind the movie. I tried it on the APEX AD-1500, which I took back to the store within 1 hr of buying it because the DVD playback was just CRAP on CRAP. I will be getting the Pioneer DV-343 soon and will try it again.
What I've notice is that when I play the SVCD on my PC the sync problems occur after FF depending on the software used. If I use WinDVD 3.1 I can FF or RW as many times without any sync problems. If I use Media Player or any of the other players the sync problems appear.
Basically, after FF or RW the Video lags the Audio i.e. you hear the sound before the scene appears. This was consistent on the Apex but the same SVCD players absolutely GREAT with WinDVD 3.1.
Has anyone found the reason why this would happen after FF or RW, especially with a standalone DVD player??
My theory is that the Video is not being decoded as fast as the audio hence the lag time. ???????
The question is how do I fix the problem.
Closed Thread
Bye,
s@d
Honestly, you could start by not irritating everyone on the boards. Here's how:
1. Don't double post your message in the same forum.
2. Don't post your message in three different forums, for a total of the same message being posted 4 times.
You've been to these boards before and been told not to do this in the past... you shouldn't be doing it again now.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
How to sync video with audio
By Denster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2010, 21:25 -
audio and video out of sync
By lbbruiser1 in forum AudioReplies: 1Last Post: 2nd Dec 2007, 11:14
