Closed Thread
  1. I need some utility to repair mpeg2 files recorded from satellite via DVB SkyStar card. Some files have so serious errors, so they even can't be reencoded, reencoding program hangs or crashes. So far I tried ProjectX (no use seems to me) and PVAStrumento - better, but repairing damages sound sync. Maybe there's some setting to improve this, but I didn't find it. Please recommend me something. Thanks.
    Jun 2004
    USA
    Give Videoredo a try! I am pretty sure there is a trial version. The support team at Videoredo is super!!
    bits
  3. Many thanks. This apllication really works. It saved almost all my recordings.
  4. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    just to add, you can do the same with mpeg-vcr 3.14.
    Oct 2005
    Australia
    I would just like to ask, is the remedy here a simple "GOP fix"? Is MPEG-VCR's GOP fixer doing the same thing as VideoReDo's Quickstream Fix?
    Would something like this be recommended for all mpegs before burning to DVD? Or is that overkill?
    May 2011
    Germany
    If you need a more versatile/professional video repair tool you should try the HD-VRT from grauonline.de.
    After a corrupted 3TB harddrive crash I had recovered my files with Filerecovery for Windows and- they were still corrupted
    Alas HD-VRT is shareware, but I got reasonable results for the MPEG2 and HD-MP4 videos with it.
    Jan 2007
    why would you post to a 7+ yr old thread from 2005
  8. Mod Neophyte redwudz's Avatar
    USA
    chrisn79, Please don't dig up old threads to post in. If you have new information, consider creating a new topic.
    Thread closed
    Moderator redwudz
