Results 1 to 30 of 32
    Jan 2003
    Sheffield
    I am attempting to convert a file to dvd using divxtodvd. I have used this prog successfully before but for some reason I get the following message when I try to convert :
    "Access violation at address 100A95A7 in module 'avcodec.dll'. Read of address 09233000"
    I have tried to post a screen shot but it won't let me paste it in on this post.
    Apologies and hope somebody can help,
    B
    USA
    What kind of video file? Drop it into Gspot and look in audio for MP3 VBR or AC3 audio. That is a common conversion problem with Xvids or Divx files. The other possibilities are a PAL video, though DivxToDVD usually handles them. Another might be something like Ogg audio or a frame size or frame rate that is really off spec as far as a DVD format goes. It sounds like a corrupt file, though.
    If you have trouble posting screenshots, see here:
    https://www.videohelp.com/forum/viewtopic.php?t=271697
    You can blank out the name of your video if you like.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I would agree with Redwudz. Either a really corrupt source, or perhaps time to reinstall DivxtoDVD
    Read my blog here.
    Jan 2003
    Sheffield
    Cheers for the replies. I am thinking it may be a corrupt file also. After loading the file into gspot I get this :
    [/img]
    Jan 2003
    Sheffield
    Ok, I have really tried to post screen shots but I can't host them online and cannot get the hang of it. Sorry for being dumb!
    Basically gspot says :
    "not a valid avi file"
    "Non-avi file. Type unknown"
    What am I dealing with here??!!!
    Thanks again for helping this dumb blonde out
    Bel x
    Jan 2003
    Sheffield
    I really REALLY need this file to play on a dvd and player. It will play on my PC using VLC but I am totally stuck now. If any kind soul feels like helping me out I would be really grateful. I will even rip the file to cd-r, post and pay somebody to have a crack at this!
    Thanks again,
    Bel
  7. Originally Posted by BPH2002
    Thanks again,
    Bel
    Hint: VLC will play incomplete downloaded video files
  8. Mod Neophyte redwudz's Avatar
    USA
    I assume you were using the latest version of Gspot? And if you can open it with VLC, what does it say under 'View', 'Stream and Media info' about the file? It may be as simple as a missing or corrupted codec, since VLC uses it's own codecs. Gspot should have told you that, though.
    And one more thing to try, drop it into VirtualDub or my favorite, VirtualDub Mod. It may give you some ideas on the problem. If it can't open it and gives up, then likely the file does have a major problem.
    If VD opens it, you could try resaving it with fast recompress it you have the same codec it uses. Then try DivxToDVD on the new file.
    Jan 2003
    Sheffield
    OK, thanks.
    In VLC under 'stream and media info' I get :
    Stream 0
    Codec: avc1
    Language:
    Type: video
    Resolution: 512 x 384
    Frame rate: 29.970000
    Stream 1
    Codec: mp4a
    Language
    Type: audio
    Channels: 2
    Sample rate: 22050 Hz
    Bits per sample: 16
    Bitrate: 705 kb/s
    General
    Duration: 1:49:39
    Apologies again for being too stupid to post a screenshot.
    In the newest version of gspot the only info I get is :
    Container :
    File type : 3GPP media (.3gp) [MP4 Compat]
    Mime type : video/mp4
    Video :
    Ready (184 codecs loaded)
    At least I have discovered it's an MP4 file, do I perhaps need a prog to convert MP4s into a different format?
    I do not really understand this 'codec' business but in virtualdubmod 1.5.10.1 the file will just not open.
    Half of me is just accepting that this will not work but the other half is hoping that this is due to the file being MP4 and can be sorted.
    Really people, thanks so much for all your input and advice. I really appreciate it.
    Bel x
    Jan 2003
    Sheffield
    That really teased me!
    Unfortunately TMPGEnc 3.0 Xpress will not open the file I am trying to play with.
    Is it anything to do with the fact I only have the free trial version (Idon't think this should matter)
    AAAARRRGGGGGHHHHHH!
    Thanks for replying though, and please keep them coming because if this keeps playing with my head I will rip my hair AND my tits out!
    Bel x
    Jan 2003
    Sheffield
    PS I have just tried MP4UI as well but it says my file is an invalid video type. I refuse to believe this cannot be done!
    B
  12. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Sounds like a you just have bad source file on your hands to me. If VirtualDubMod chokes on it, that's not a good sign at all.
    Also, do you have a webcam? You know, for the pulling the tits out thingie you mentioned earlier.
    Regards,
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  13. Mod Neophyte redwudz's Avatar
    USA
    One last shot at it. This program may be able to convert it.
    https://www.videohelp.com/tools?tool=Mobile_3GP_converter
    It may be a form of Quicktime, used for digital phones.
    BTW, I admire your persistence.
  14. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    There is one last ditch option. If VLC plays it, you could try to use FRAPS to record it as it plays back, and then use the fraps output for conversion. It is the long way around, but if your need is great enough, the effort will be worth it.
    Read my blog here.
    Jan 2003
    Sheffield
    3gp converter is a no go.
    Just d/ling fraps now but I don't hold much faith, corrupt file acceptance is such a downer, I REALLY wanted this movie, I will have to pay £35 for it now. Hey ho!
    Thanks to everybody who replied and helped, you're all diamonds.
    Will check back to let you know how fraps goes.
    PS I do not have a webcam!!!!!
    I have a digital camera though......
    Thanks again people,
    Katie-Belinda x
    Jan 2003
    Sheffield
    Fraps does not work with XP!!!!!!
    May install a V/M with 98 to see if that works but my patience is running thin.
    Thanks again, and in summary,
    THANKS TO MY CORRUPT FILE!!
    B x
  17. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    According to the site, version 2.7.2 (the current version) supports XP, 2003, and XP64 edition. What version do you have ?
    Second, if you have an older version, you could try compability mode - find the exe, right-click and select properties. Go to the Compability tab and set it to win 98.
    But this is moot - it does run under XP.
    Read my blog here.
  18. Member
    Jan 2003
    Sheffield
    OK I now have 2.7.2, this will sound silly but I can't seem to work out how to even 'load' my file into it. I have searched the site for a guide but didn't find anything.
    Thanks for this x
  19. Hmm, maybe try AviDemux2. It can deal with a lot of file types, well I don't know. Good luck.
  20. I'm a MEGA Super Moderator Baldrick's Avatar
    or try
    install latest ffdshow, it can decode avc/h264.
    try play it with windows media player.
    if you can play it you can use avisynth, https://forum.videohelp.com/viewtopic.php?t=284288
    open the avs in your encoder.
    Jan 2003
    Sheffield
    Thanks alot, I will give them a shot. Sorry about the locked posts, I didn't mean to clutter up the board.
    Thanks again
    K
  22. Member
    Jan 2003
    Sheffield
    Hi,
    I could not even download AviDemux2 for some reason and ffdshow doesn't take the file. It does not open with windows media player.
    I am fairly sure it is an mp4 file, but mp4i would not open it either no guess I'm wrong there.
    What a nightmare, I am not very 'up' on all this sort of thing but really perservered with this one, I felt sure I would crack it if I kept it up.
    I think I am finally giving up, thanks to everybody who left comments and suggestions, I really really appreciate it. I may not have achieved my goal but I have learnt alot along the way.
    Thanks again,
    Katie
  23. I could not even download AviDemux2 for some reason
    When you click on Download at left side of the main download page, you get new screen where you click on windows instaler.
  24. Member
    Jan 2003
    Sheffield
    Cheers ABond, avidemux2 is not recognising the file though.
    MP4 to dvd programmes are a no go as well.
    Big thanks to Randy who is going to have a crack at this for me, I salute you!!
    I will let you know how this goes for the sake of any person who may have this problem in the future.
    K
  25. Member
    Jan 2006
    Victoria, BC Canada
    Katie,
    Don't freakin give up. I am having the same damn problem. I know this much, .mp4 is what is used for UMD's for PSP i believe. The codec needed to play a mp4 video is AVC1. This is where i'm stuck. I can't find any avc1 codecs. All my searches lead to ffdshow, which doesn't work either. Anyone have any updates?
  26. Member
    Jan 2003
    Sheffield
    Mate I gave up! I tried everything! Some kind soul in USA contacted me and said he would have a go at it since he hadn't come across a file that could not be manipulated as desired. The second he cracks it (I hope) I will contact you and let you know how it's done. Fingers Crossed!!
    K
  27. Member b1tchm4gn3t's Avatar
    Nov 2003
    Illinois, USA
    the kind soul sent that dvd out to you yesterday...enjoy!
    If at first you don't succeed; call it version 1.0
  28. Member
    Jan 2006
    Well, does that same kind soul intend to tell the rest of us how it was done?
  29. Member b1tchm4gn3t's Avatar
    Nov 2003
    Illinois, USA
    When I find the thread I used to get the job done I will post back.
