Here recently my taskbar often loads up with everything out of place when I boot my PC. I'll have several entries listed for the Language bar but only one in the actual taskbar and I believe this may have something to do with it. I can uncheck all listings of it and then reload the one remaining (it appears as "language bar" where the other two instances appeared as "The Language Bar" and it is back in place. But I still have to drag my taskbars around to get it all lined back up. The main bar starts shrunken up over near the system tray so application tabs are stuffed over in the corner. I also seem to have an extra empty space showing when unlocking the taskbar. Anyone know what could cause this or how to fix it?
That's the space used by Toolbars but I cant figure out why nothing is indicated there.
I'd run an adware scanner just to rule that out first.
I'd like to know how you got the taskbar to turn black. -
I run ad-aware, Spybot, Spywareblaster, and MS Anti-spy frequently. Nothing to do with spyware. The taskbar being black is just a modified theme used with a uxtheme patch. I've had that setup for ages and never any issues with it.
What skin you using on your taskbar? It looks nice.
I'm a huge fan of RoyaleMod.
http://www.deviantart.com/deviation/8521744/ -
I think it's the final cut of a theme called Glowing Purple. It's not a full theme package though just a style a believe.
Banks are so freaking greedy
By stiltman in forum Off topicReplies: 12Last Post: 17th Oct 2011, 07:58 -
ffmpeg seek bar (or timing bar)
By Seven40Rob in forum ffmpegX general discussionReplies: 1Last Post: 7th Oct 2008, 23:36 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29 -
Task Scheduling
By Squid_uk in forum ComputerReplies: 1Last Post: 16th Apr 2008, 13:33 -
what tool for this task?
By pheldd in forum Authoring (DVD)Replies: 7Last Post: 5th May 2007, 20:58
