  1. hello...
    i own a Sony dvd player (DVP-NS32) which supports DivX.
    on this site i found out that it also supports xviD if you "change the file header".
    I don't know what that means exactly though...
    can anyone help me with this?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You could just try them and see if they work. If they don't, I believe the app you are looking for is MPEG4 Modifier.
    Google is your Friend
