Hi everybody,
I´m trying to add a subtitle (.SSA) to a 160 X 220 AVI using VirtualDub (v1.6.11). I´ve already installed "Subtitler" plugin (copy "Subtitler.vdf" to /plugins in VirtualDub folder). When I selected in VirtualDub, Video> Filters>Add>Subtitler>Ok>Select Subtitler (.SSA)>Show Preview, I can´t see any subtitles added in the preview.
What is wrong? Any other parameter that I have to configure in order to see the subtitles added to this AVI?
Below, the file information of this AVI from VirtualDub:
Thanks.
At that res would you even be able to read them? Certainly not ssa effects. You could try textsub (part of VSFilter), supports way more formats so you could convert to a simple format like srt. The other advantage of vsfilter is that it is also an AVISynth plugin. If you use it via AVISynth then you can avoid converting to RGB24.
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 05:12 -
adding subtitles to avi file
By dragonhead08 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jan 2009, 09:18 -
Help Adding Subtitles to an AVI while converting to an MPEG
By canas15 in forum ffmpegX general discussionReplies: 8Last Post: 27th Dec 2008, 00:28 -
Adding subtitles to an AVI
By ker-plop in forum MacReplies: 12Last Post: 8th Oct 2007, 09:48 -
Adding Subtitles To An .AVI File
By thesal523 in forum SubtitleReplies: 2Last Post: 10th Aug 2007, 13:16
