Yes but I have 70kbps version too.Originally Posted by sdsumike619
Depends how you want to go about it, as I said there's many ways. you could even link it to playlist from a drop down menu. I don't have the code handy but if google it you'll come across it pretty quick.any idea about having several links to videos open in the same video player window?
Results 31 to 34 of 34
any thoughts on the MBR setting for wmv in Sorenson Squeeze? What exactly would I type in Google to find out about linking several videos to the same embedded player? (thanks for your help by the way)
That's the first I've heard of that, I've never seen a script for doing it. Never looked either, probably require javascript which I don't like using if possible if you were doing it in a html page. If you can pull that off with Flash that might be better because you can jack the bitrate up insanely for high bandwidth connections.Originally Posted by sdsumike619
My only point was that WMV produsces a higher quality file at lower bitrates, at least compared to your examples.
Maybe "embed media player"What exactly would I type in Google to find out about linking several videos to the same embedded player? (thanks for your help by the way)
You'll find literally thousands of examples for different ways of embedding a media player. Even ones for using the users default one...... try adding drop down list to the search.
ok, well that MBR thing didn't work at all! I went on netzero dialup and tried it and nada, it didn't "adjust based on my connection" However, the flash on the dialup at least played some b4 it had to download more, the wmv didn't do crap so based on everything, flash is the way to go.
Sorenson Squeeze 5.0 and QT
By rotuts in forum MacReplies: 3Last Post: 9th Dec 2010, 16:41 -
Sorenson Squeeze
By kr236rk in forum Video ConversionReplies: 36Last Post: 27th Oct 2008, 08:50 -
Sorenson Squeeze Problem
By seven_deuce offsuit in forum Video ConversionReplies: 0Last Post: 15th Nov 2007, 22:24 -
sorenson squeeze 4.3 problem
By Davide vr in forum MacReplies: 0Last Post: 12th May 2007, 21:55 -
Sorenson Squeeze 4.5?
By jupiter84 in forum MacReplies: 1Last Post: 9th May 2007, 02:46
