burning using nero of 1 gigaabyte video file into 2 vcds. How to cut file to fit into 2 vcds.
Are you creating VCDs, or do you simply want to split an avi onto 2 CDs ?
VCD requires reencoding to VCD standards using mpeg-1 video. You can fit approx 78 - 80 minutes of VCD video to a 700 MB CD. Look up VCDEasy in the tools section and read any associated guides.
If you just want to split an AVI into two equal (or unequal) parts for writing to 2 CDs then use virtualdub in Direct Stream mode, set markers for the first half and save, repeat for the second half. Direct Stream Copy will not reencode the video.Read my blog here.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
HD cam under $800
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 139Last Post: 7th Dec 2011, 15:17 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 06:06 -
ExpressCard / 34 slot vs Firewire 800
By Sjogogo in forum MacReplies: 4Last Post: 6th Dec 2010, 00:54 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:26
