I have a program I recorded from TV with my DVD Recorder and can't seem to rip it to my Hard Drive with DVD Decrypter. It plays fine in the Recorder but when I try to rip it I end up with the following message(s) after about 46 minutes of the 64 minutes have been ripped. I've done this many times before with no problems. Can anyone tell me what this means and what to do about it?
Any help will be very much appreciated. Thanks!
.....Gord
Thanks to ImageShack for Free Image Hosting
Results 1 to 11 of 11
Outside a dog a book is man's best friend. Inside a dog it's too dark to read.
------------ Groucho Marx -
There is really no need to use decrypter, since it is not encrypted. You can just copy the files using windows explorer.
Believing yourself to be secure only takes one cracker to dispel your belief. -
I understand that. What I want to do is demux to separate streams and then use Cuttermaran to cut out some of the beginning and ending of the video. Also, I did use Windows Explorer to copy it to my Hard Drive. I then tried to demux them and had the same problem. I tried using DVDLab Pro to demux the files but ended up with exactly the same short video that I did with DVD Decrypter. I'm lost as to what to do now.
Thanks for the reply.
.....GordOutside a dog a book is man's best friend. Inside a dog it's too dark to read.
Thanks but I tried DVD Shrink and it won't open it either. I get this error message:
Any other ideas would sure be appreciated!
The recorder is a Philips DVDR 75.Originally Posted by hech54
I'll give ISOBuster a try. I've never used it so this could be interesting.
Thanks for the help.
Are you sure you finalized the DVD in your recorder?
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
If you are using a +R - Finalize it.
If you are using an RW disc - Protect it.
The more you attempt to crap on that disc(4 hours, 6 hours)....the more difficult it will be to work with that disc on a computer.
I have a Philips DVDR985....even older than yours...
@GordRocks
Yep, IsoBuster is great when you hit something you can not get any other way!! I have used it to rip files from dvds/disc's that would not even show up as having anything on them.
And i dont know about the Philips, i would assume they are all the same, but when i dont finalize a dvdr in my standalone it wont even show up as having anything on the disc in any of my pc drives with any program except IsoBuster!!
Ive had a few disc's that i could not get to finalize and the only way i could get anything off the disc was with IsoBuster!! great program to buy, IsoBuster Pro 1.8
Help Ripping DVD by Chapter with DVD Decrypter
By lukebrowning in forum DVD RippingReplies: 3Last Post: 11th Jan 2011, 00:04 -
Trouble ripping The Ugly Truth with DVD Fab HD Decrypter
By heyjjjaded in forum DVD RippingReplies: 1Last Post: 22nd Dec 2009, 14:29 -
Questions About DVDFab HD Decrypter; Ripping MPG
By neumannu47 in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2009, 18:55 -
Any Free Alternative To DVD Decrypter For Ripping To Single VOB?
By DarrellS in forum DVD RippingReplies: 9Last Post: 11th Feb 2009, 00:41 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 13:11
