Hi everyone,
Does anyone have the media code for the printable 16X TDK -R that are being sold at Costco US? I picked up a 50 pack of the 8X printable -R a few months ago, and they worked pretty well. But I noticed that Costco has replaced the 8X for the 16X, so I am wondering if the quality is still the same...
(And do these 16X have the same hub size as the 8X?)
Thanks in advance!
Spiffy
Results 1 to 9 of 9
As you are probably aware, Costco has a very fair return policy for their members/customers, so if they do not work for you, I expect they will take them back and return your money with no problems. That's the great thing about buying from Costco.
AFAIK all TDK 16x DVD-R media carries the media code TTH02 regardless of where made (Japan, Taiwan or Luxembourg).
** WARNING : Some Drives Do Not Return The Entire 'Media Code'-Block
When Dealing with Discs That Are Rated 6x And Higher.
** INFO : Hex Dump Of 'Media Code'-Block Listed Below
** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded
** INFO : Format 0Eh - Pre-Recorded Information In Lead-In
0000 : 01 40 c1 fd 9e d8 52 00 02 84 0d 12 98 99 90 00 .@....R.........
0010 : 03 54 54 48 30 32 00 00 04 00 00 00 00 00 00 00 .TTH02..........
0020 : 05 88 80 00 00 00 02 00 06 09 0a 15 98 89 90 00 ................
0030 : 07 88 80 00 00 00 00 00 08 07 14 0a 0e 09 04 00 ................
0040 : 09 95 07 0d 0b 88 88 00 0a 80 00 00 00 00 10 00 ................
0050 : 0b 06 17 15 b8 99 85 00 0c b8 9a 32 03 20 32 00 ...........2. 2.
0060 : 0d 00 00 d0 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0080 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00a0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00b0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00c0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00d0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00e0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00f0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ -
These discs have worked fine so far for me. I burned 5 of them, and I purchased 2 spindles of 100.
No burning problems, or playback/reading problems from my old Pioneer A05 drive -
I just burned around 300 of them with my acard duplicator and 7 pioneer burners. 3 dvd 108's and 4 110's
Although, I think the 8x ones were quicker. -
Hmm, so which manufactur actually makes TTH02 then?
I am perfectly happy with the 8X and don't have the need to get the 16X; but since that's all they have, I don't have any choice. -
TDK makes them if they're from Luxembourg or Japan; if from Taiwan they are made by CMC Magnetics to TDK's specifications.
Quality TDK Media?
By hech54 in forum MediaReplies: 15Last Post: 24th Jan 2010, 19:42 -
Will media ever go beyond 16X?
By videobread in forum MediaReplies: 7Last Post: 22nd Aug 2008, 12:16 -
Phillips DVD+R, 16x, media code: CMC MAG. M01...These any good?
By i am x in forum Newbie / General discussionsReplies: 1Last Post: 15th Mar 2008, 10:26 -
Starlogic 16x R+ Media
By joefromflorida in forum MediaReplies: 3Last Post: 31st Jan 2008, 21:17 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 10:29
