Ok I was making some dvd's out of avi's.
I used winavi then nero to burn them. BUT when you
played them in a set top box they would not continue from stop.
Normal dvd's allow you to continue from the place you stop.
SO winavi, tmpgenc and tmpenc Author and everything worked fine.
When you hit stop on a dvd the player would say the dvd would continue from
where it was stopped next time you hit play.
BUT I now have 11 dvd's that won't work, made them before I found out this error.
HOW can I redo these dvd's so I can get them to work?
Convert them back to mpeg then do what I found out would work?
Is there a dvd copy utility that might fix this type of problem or ?????
I am lost...completly
thanks for any and all help
I sure wasted a lot of time and dvd's learning how to do this correctly.
But that doesn't help on the ones I already have with no originals
ps they are mst3k movies copied from my tapes....man thats a lot of work
anyone in the world got the first 4 episodes
thanks again
Etrin
Originally Posted by etrin
http://www.mst3k.org/
I'm afraid I can't help with the rest.
.....GordOutside a dog a book is man's best friend. Inside a dog it's too dark to read.
------------ Groucho Marx -
So you are saying that the ones authored with TDA worked correctly, allowing your player to stop and resume from the correct point ?
If so, you can use DVD Decrypter to rip the originals to your HDD, and TDA's Add Video (or Add Movie - can't remember the exact wording) function to load the VOBs from the originals into a new disk. Author, burn and test.Read my blog here.
Question about Video Redo
By snafubaby in forum EditingReplies: 6Last Post: 26th Feb 2012, 04:01 -
How do I Redo Subtitles of TV series on DVD and delete dubbing
By killinmesmalls in forum SubtitleReplies: 8Last Post: 21st Jan 2010, 13:34 -
GUI for DVD and Video Redo both crash Win2k
By Skarr11 in forum Authoring (DVD)Replies: 1Last Post: 20th Jul 2007, 17:02 -
Redo chapters in a DVD
By zakman in forum DVD RippingReplies: 1Last Post: 24th Jun 2007, 15:19 -
Picture Quality Question on made DVD
By Superstar24 in forum Newbie / General discussionsReplies: 24Last Post: 26th May 2007, 00:35
