Can someone tell me the best settings for avi to (S)VCD conversion???
I use Tmpgenc.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
The standard settings of the pal of ntsc(film) templates of TMPGenc are for most ppl already the best settings you can get.. maybe you should turn the encoding quality on 'highest quality' instead of 'normal' but if you use the templates you will already be amazed of the results. Try to keep ntsc to ntsc and pal to pal because of frame de-/increasement which has unpredictable side-effects.
From DV-avi to MPG, I think its MPG2 SVCD template is good with the bitrate setting. Changing the quality too 100% and the motion search to high, the quality is close to the DV-avi when playing on TV.
And what about source aspect ratio???
I always put it on 4:3Display.
I already tried 1:1(VGA) but the Quality was really Bad.
See,I only need the settings 4 the best VCD Quality but i do not want to take more than 2 700MB/80Min CD-R for around 90 Min of a Movie.
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
How to make an AVI better quality (keeping output still as AVI)?
By Dogpoundz in forum Video ConversionReplies: 15Last Post: 22nd Sep 2011, 00:12 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
avi quality better then vhs quality?
By NateDizzle in forum Video ConversionReplies: 7Last Post: 11th Jun 2007, 08:20
