Please help, i have put three clips into TDA to play as one combined and also added an MP3 file for background music, but the MP3 track restarts every time there is a join in the clips, DO i have to merge the clips before putting it into TDA or what![]()
Results 1 to 14 of 14
Originally Posted by efiste2
I didn't think TDA would accept MP3 as it's not DVD spec."Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
How did you join the video clips?
Buy My Books -
Using TDA i add a new clip every time, (ie all the clips go into one file)then cut the frames either side of ther join, and then.........CREATE the VOB file. THEN i reopen TDA and load in the newly created (joined files) then add the audio track to the ONE BIG FILE. but still no success. ID probably be better using WINDOWS MM but all the clips i want to use are in VOB format and converting them back to an AVI seems pointless and aslo the ones that i have tried either skip or loose quality, ANY SUGGESTIONS
I've never tried joining files in TDA, but it sounds like that should have worked. At this point I'm not sure where to go next, but maybe some exploratory questions might spark something.
How long is each clip by itself?
How long is the total video (when all the clips are joined)
How long is the music file?
When you pull the newly created VOB into TDA does it already have chapter points? (Or are you prompted to preserve chapter points?)
Why do you "cut the frames either side of ther join"?
How many frames are you cutting?
(Like I said, this is just exploratory. I'm not sure if the answers to any of these questions will give us a clue, but you never know.)"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
the clips are only about 15-30 seconds long, and to make the join a bit smoother i take the frames either side of the join out, the whole file is INTENDED to be about 15-20 mins long but im just trying it out ao i know it can be done, the audio track is about 2 minutes long. and hve deleted all the chapter point out, Thanks very much for trying to help me out, its much appreciated!!!
When you say you deleted the chapter points out do you mean before creating the VOB, or when importing the newly created VOB?
There may be an issue with the music length being different. Whenever I've added a seperate audio file it was always the same length as the video file I was working with."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
heres where the audio track starts repeating, with all chapters removed and everything. the two little marker arrows on the picture
I don't think I've ever seen little marker arrows like that in my timelines. What version of TDA are you using? Also, under the slidebar there is a mark that indicates that there is a chapter point close to that position, so I don't think you've removed all the chapter points.
Buy My Books -
all chapters are out, must have missed the one in the pic, but ive just done another and the arrows still appear and the audio still restarts at the original clip joint, do you know of any other way to join vobs..........as it looks like TDA cant do what im trying to do
Buy My Books
TDA problem of GOP
By sumeshkri in forum Authoring (DVD)Replies: 2Last Post: 29th Feb 2008, 01:29 -
TDA 3 Quirk
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 8th Oct 2007, 10:37 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 18:04 -
TDA 3 Sound Problem
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2007, 14:43 -
TDA 3 Questions
By pepegot1 in forum Authoring (DVD)Replies: 2Last Post: 16th Aug 2007, 12:03
