I'm looking for recommendations for a VCR to dub about 120 2-hour (all recorded at SP) VHS tapes to a HDD DVD recorder. None of the tapes are S-VHS but the majority of them are in excellent condition considering that some are up to 20 years old. I plan to record to DVD at no worse than SP speed so I'm looking for a VCR that puts out really clean output.
I'm looking at the JVC HR-S5902 for $145 at Vanns (http://www.vanns.com/shop/servlet/item/features/473179805). I really can't go for the $400 HR-S9911U unless the results are clearly obvious to the untrained monkey. Is there any better solution for under $200?
Thank you!
Tim
Results 1 to 30 of 65
Hi tluxon and happy holidays BTW, I purchased that very same model some months ago to dub my VHS tapes, I use s-video cable and it gave me very impressive results compared to the cheapy VCR I had before. The only thing that I don't like about it is it has a "Video Calibration" system that you need to turn off otherwise "Video Calibration" will activate and flash each time it tries to adjust the tracking which will show up on your dvd recording so I just turn it off and adjust the tracking manually if needed, other than that it's a great unit.
Also be aware that depending on the quality of your tapes, some recorders might think that they are copyright and stop recording, you might want to look at purchasing a recorder where the Macrovision can be relaxed allowing you to copy your home videos, the Liteon 5045 (with HDD) with appropriate firmware version would be my suggestion for your project.
Cheers
CC -
Thanks for the input.
I wonder if the S9911U also flashes "Video Calibration" when tracking adjustments are made automatically?
When you researched your 5902, what other VCRs were in the running in a similar price range?
I already have the LiteOn 5005 with Guitarman's firmware mod for tapes that have macrovision effects. I'm leaning a little toward the JVC DR-HM30S because of its PQ and the fact that it has a multi-brand remote, which the LiteOn doesn't have. -
In regards to the "Video Calibration" message. There is an option under Menu|Function Set called "Superimpose" and if you set it to 'off', you will not see the message that CrazyCanuck is refering to.
I am very happy with my 5902. It is also a good tuner for Lite-on's. I use the 5902 with my 5014. -
My last used S-VHS unit was betwee $150-200 used, and is in perfect shape. I helped two other people do the same thing.
eBay and people I know.
eBay works well. The way to know is to read auctions, buy from reliable sellers (check feedback for comments from BUYERS), and ask questions if you have any.Want my help? Ask here! (not via PM!)
Try and find a Hi-Fi Stereo 6 Head VHS VCR by TOSHIBA on eBay. The top of the line model adds DNR and the very top of the line has DNR and is S-VHS.
Personally I don't think you really need the DNR but I guess it would be nice to have if you can find one ... that's the trick these days.
The old 6 head Toshiba VHS VCR's were rather spectacular. Shame they are not made anymore.
What format does the VHS-to-DVD product record in? MPEG-(?)...
I myself am looking for something to "quickly" put old home VHS's straight to DVD, to edit at a later date.
Any suggestions?? -
Originally Posted by HomeMovietoDVD
The Pioneer DVR-531H-s can be bought at WALMART for just under $300 which is a great price for a DVD recorder with a built-in 80GB HDD.
Will it copy to a format I can edit later, when I have the time?
Originally Posted by FulciLives
This site has a lot of folks that know quite a bit about VCRs. Have you got any inclination as to what is wront with the Mitsubishi? If so, then I suggest you start a new thread on it, in an attempt to fix it. The restoration forum would work fine, since it's a piece of advanced hardware.
Also be sure to take care of the Toshiba with regular cleanings after so many hours of use.
It sounds like you already have some great equipment, just not working entirely.Want my help? Ask here! (not via PM!)
Well I could've sworn I still had that Mits up in the garage but for the life of me I couldn't find it after looking high and low for it for at least two hours. I remember asking for advice on it back in April 2005 and being led to the VCR repair website, http://www.fixer.com/, so I was certain I still had it because I don't remember giving it away and I can't imagine that I would've sold it.
So, if I'm going to fix any old higher quality VCRs all I have left is that NEC (I found the manual and see it is a N895EU) that I bought back in late 1985. It is literally a tank and has worked every day since I bought it without anything more than a periodic tape cleaner being run through it. Any chance it would be worth it to fix and end up being better for tape transfer than the JVC HR-S5902? -
Tim -
i bought a JVC 7600 off ebay for 150 dollars CA. And the guy threw in MOnster s-video cables and audio cables to boot.
Okay, so if I want to pick up a better older unit off of eBay, what models are going to be better than the JVC HR-S5902?
Thanks! -
Anything HR-s5903 and up i would imagine. But dont get suckered into a bidding war on any of the 9000 series VCR's theyll sell for 250-300 bucks used with nothing with em, but you can buy now a 9911 on ebay for 250 bucks.
It's mostly the 7000 and 9000 series JVC units that are the better units.
- John "FulciLives" Coleman
Here is a nice looking 6-Head Toshiba I found on eBay: Click Here
I once had 4 of these at once ... excellent model. No DNR but who cares! Actually mine was the 784 I think and this says 785 but it looks exactly like the models I had which did not have DNR but the eBay auction says the 785 does have DNR which is ... hey ... even better I guess"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
So you don't think it's essential to get an S-VHS deck? On the Toshiba M-785 you found it doesn't look like there are any front video inputs, which the kids need because the TV doesn't have them. Of course, I guess they could always use the jacks on the DVD recorder.
Here's a few S-VHS JVC VCRs I picked out on eBay because they looked like good ones. Would someone mind taking a look and advise if one of these would be best suited for VHS -> DVD transfer and/or perhaps make some suggestions?
JVC SR-TS1U PRO S-VHS SVHS SUPER VCR EDITING DECK NR
JVC HR-S7800U SUPER VHS VCR - EXCELLENT CONDITION!
JVC-HR-S9911U Super VHS 4 Head HiFi VCR SEALED HR-S9911
Thank you! -
https://forum.videohelp.com/viewtopic.php?t=287476 -
My understanding is that a S-VHS VCR only makes for a better source when playing back a factory made VHS/S-VHS video OR when playing back a real S-VHS tape be it a factory made tape or one recorded in a S-VHS VCR. It really should make no difference when playing back VHS videos that were recorded on another VHS VCR.
My experience is that Toshiba used to make the best VHS VCR's and you said yourself that your Toshiba is the best looking VHS VCR you have ever owned.
Tis a shame they are no longer made this way but hey ... that's what eBay is for
Originally Posted by davideck
I have dubed quite a few VHS tapes to DVD
I have a a ilo RHD04 $198.00 and a Go Video DV2150 Combo $70.00.
The VHS has 4 heads will record.
The go Video VHS not for recording [play only] and the DVD is play only
The Go Video feeds the ilo and does an outstanding job.
I also have two Very good 4 head Panasonic VHS and a 6 Head VhS.all older.
I also have an old very good 2 head VHS that plays as good as tha prior units mentioned but is not as good when recording which is why the 4 head unit came along. If your tapes are 20 some years old they may have been made on a 2 head machine.
It should be noted that only two heads are used in playback. The other heads are used in recording and were used for a [Quote 'better recording']. Actually a good two head unit would do the playback job but try and find one
When dubbimg VHS to DVD You want to use SP. The resolution of VHS was not that good to begin with and I'M sure tha t a DVD in LP willL look as good or better than the VHS. I've even used EP without a real noticeable difference -
I would definitely recommend an S-VHS VCR. Since Luminance and Chrominance are recorded separately on tape and processed separately by your capture device, it is best to keep them separate by using an S-Video connection between your VCR and capture device. Otherwise, the two components will be mixed into composite in the VCR only to be reseparated by the capture device. This process can sometimes introduce noticeable artifacts.
I also find that my SVHS VCRs typically play back my VHS tapes better than my VHS VCRs, particularly pre-recorded commercial tapes. -
Originally Posted by LCSHG
The reason is that the tape runs so slow at 6 hour (ep) speed the wide heads would overlap the last track being recorded. OTOH the wide heads should give results at preventing dropouts and a better s/n ratio to the recorder electronics.
There are/were other units that had other features to improve recording and playback of course. Not to mention flying erase heads to allow better insertion of video when editing. -
Based on what I've read on this site, I'm guessing that of the three eBay VCRs I linked above, JVC HR-S7800U SUPER VHS VCR - EXCELLENT CONDITION! would be the best of them?
If I stick with S-VHS and happen to find something other than a JVC, which ones should I be looking out for? -
[ TBoneiT ]
I don't believe a two head Recorder is being made.
The 4 head units are common.
I believe that JVC still makes a 6 head unit that is for super VHS etc.
The heads were sometime back, some 25 microns.
All the heads today are 19 microns. There was a move to reduce to less than 19 but I think this was dropped because of DVD Disk.
I am not aware that any 4 or 6 head units, have two size heads
I can not see why you would want any overlap on a recording. This would cause a severe tracking problem. The main reason for the 19 micron heads was to help eliminate any overlap and a resulting tracking error
The head rcords in a helical pattern across the tape and depending on tape speed it will record information over a greater or less tape length.
Naturally the greater the length the better the resolution, as the bit rate in DVD disks.
In recording the 6 head JVC might do a better job especially using SVHS etc. I really think that very few are doing this. They will still use 2 head for play, any more is no gain
Today, I think most heads used by VHS manufactures are fron very few vendors. Most are very good quality and I think that any good unit will play a Tape as well as another
VCR Comparison: JVC SR-W5U vs JVC SR-V101US
By robjv1 in forum RestorationReplies: 18Last Post: 22nd Apr 2021, 03:36 -
Anybody need a JVC S-VHS HR-S9911U VCR?
By colt4523 in forum Capturing and VCRReplies: 2Last Post: 7th Sep 2010, 19:26 -
JVC HR-S3900U svhs vcr
By DVWannaB in forum RestorationReplies: 1Last Post: 8th Dec 2009, 12:20 -
Refurb JVC HD VCR's
By victoriabears in forum Newbie / General discussionsReplies: 0Last Post: 21st Jan 2009, 12:58 -
which is prefered jvc vcr for transfer?
By greenbag in forum RestorationReplies: 19Last Post: 27th Dec 2008, 20:08
