I'm hoping I can figure this out. So far I cannot come up with a direct 3gp to mov config that gives me the proper video in it's entirety. I've tried alot of different settings. I'd love a solution.
What I have been doing to get around this is 3GP to AVI to MOV. I have again tried tons of settings and cannot get anything that gives me the quality I want.
The fact that the quality is so minimal to begin with really makes me want to keep the quality there is intact. So far it comes out a fair amount more pixelated.
These files are so small that all the processing is fast. Does anyone know what I can do to maintain quality to it's fullest?
I'm starting to get frustated. I just want an end file that has the same resolution as the origional 3gp.
Thanks in advance (I hope)
Results 1 to 12 of 12
If you have QT 7 you can use the free QTAmateur.
FWIW, I tried converting from 3GP to .MOV with the ffmpegX preset myself and had no problems.
I know my Motorolla v551 has a low framerate, the footage looks choppy, or jumpy. I'm not sure how many fps it shoots but it is not enough for fluid playback. It seems like the frames are all smooched into the first 20% of the outcome MOV file and the rest is left blank white while the audio continues in real time.
Oops, I looked just at the first few seconds when I thought it had converted properly. Now that I take a closer look I can see that ~the second half is white, just as you said.
You sure you can't use QTAmateur? VT Link.
Highest quality backups
By freewave in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2010, 19:32 -
Converting mov to flv... looking for highest quality possible.
By david pro in forum MacReplies: 2Last Post: 27th Nov 2009, 05:57 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 17:51 -
Highest quality codec
By chizzle in forum Blu-ray RippingReplies: 6Last Post: 11th Feb 2009, 15:57 -
Problem after convertng Mov to 3gp
By JayxDee in forum ffmpegX general discussionReplies: 2Last Post: 27th Jul 2008, 06:37
