    Oct 2003
    Canada
    I have about 50 one hour episodes of a TV program on tape.
    I really want to keep as much quality as possible. Each tape has four episodes on, each around 50 minutes. Without splitting episodes across DVDs I can really only get one episode per DVD. Is there a way to get more episodes on DVD qithout compromisond video quality?
    I have Dual Layer DVD burner, but am not sure how that works.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You should be able to get at least 2, most likely 4 per DVD. I expect you are capturing at too high of a bit rate...especially with your source being vhs tape.
    Google is your Friend
  3. Banned
    Freedonia
    You're leaving out a lot of details, like what you are using to capture your video (brand of card), how you are recording it, etc. I'll give you a short description of how I would do this, which might be of help to you.
    First of all, I would record my videos using my Hauppauge PVR-350 to my hard drive using standard 720x480 DVD settings and a constanst bit rate of 9000 Kbps for MPEG-2 video. I'd set the sound around 224 Kbps. After recording to disc, decide how many episodes you want to put on one DVD. I think you could fit 2 per DVD for sure in very good quality, maybe 3. 4 would be pushing it, but ultimately that is your decision. Everyone has their own idea of quality. After deciding how many episodes to put on each DVD, use a bit rate calculator to figure out what the bit rate should be and go a little under that figure.
    Finally, I have CCE as en encoder. I use a method described in the Guides section at http://www.doom9.net (they don't allow direct linking to guides - sorry). Look under Guides, then DVD/miniDVD, then DVD Encoding Guides, then CCE. I have an old copy of CCE, so I use an older version of the guide. I do a 3 pass, VBR encode with my average bit rate being a little lower than what the bitrate calculator said to use and I set the max and min values about 1000 above and below the average.
    An easier way to do this if you have a good quality video input card is to just calculate the bit rate and record in CBR at the right bit rate to fit your video on one DVD.
    The method I recommended will require some effort on your part to do things you haven't done before. If you want to do this the easiest way of all, you can buy a standalone DVD recorder and just record straight from video tape to it, but you will get better quality if you do the recording/encoding on a PC. Doing it on a PC takes longer and requires more work from you. If you decide to buy a standalone DVD recorder, I recommend not doing more than 2 episodes per DVD. Putting 4 on a DVD could result in lower quality than you will like.
    Oct 2003
    Canada
    O.K.
    I capture with an ATI Theatre Pro 500 card. I capture as an AVI using Pinnacle Studio Pro 9.
    I edit and then save as an MPeg at Pinnacles DVD quality.
    I then burn with Nero.
    I use Pinnacle Studio, as it's the only one I can get working with my system without dropped frames or out of sync audio. Sony Vegas just crashes the minute I try to capture.
  5. Mod Neophyte redwudz's Avatar
    USA
    Assuming VHS tape and a length of 3hrs, 20minutes, you could use a bitrate calculator to determine what bitrate to use to get one tape per DVD. At that low of bitrate I would use 1/2 D1 (352 x 480 pixels MPEG2) format. Try encoding a 5 minute representative clip and see what it looks like.
    If that doesn't get the result you want, up the bitrate and put 2 or 3 episodes per DVD. If you can't do that with Pinnacle Studio, try a different encoder.
    Bitrate calculators: https://www.videohelp.com/tools?s=1#1
