Hi I got a 4cd film that are .bin file and wanted to put them on a dvd-r, i have used svcd to dvd and now have a svcd output folder with the svcd converted files in there ie audio_ts and video_ts
the problem im having is that when i burn the video_ts file along with the audio_ts file using either nero or imageburn the completed dvd only has the audion on it when i play the dvd and no picture, i have ruined my 10th disc now trying to get this right,
any help or suggestions would be much appreciated
thanks
Well, you could start experimenting with RW discs for starters.
2nd, not all players play SVCD mpg authored as DVD.
I've succesfully used svcd2dvdmpg, then authored with TDA. But as I said, if you have a stubborn DVD player, your only option might be to reencode the SVCD mpg to DVD mpg.
/Mats -
To start with , one should always author to folder ... it allows you to play check before wasting dvd's ...
As for svcd on dvd ... a new guide will be online shortly covering vcd's on dvd with all the trimings .. it will be worth your while .
Were talking motion menu's , motion chapter menu's , multiple subtitle's , multiple audio sellection , the works .
You can pick just the nutts and bolts from the guide ... and it will work ... I dont use ifoedit to tinker with things like others do in some of the guide's .
My dvd players are considered valued friends ... beats the crap on the box when there is nothing too watch ... repeats ... again ... bugger .
Should have the basic's of the guide posted shortly , maybe xmas day .
As for subtitle's and multiple audio languages part , I'm still working on that part of the guide , so I'll post what is available now , and add the rest later ...
This will blow people's sock's off ...
The following guide after this one is completed is for fun , using flash funnies ... such as jerbal in a blender , and other's to create the most entertaining dvd yet ... -
Downloaded that svd2dvdmpg but keep getting an error message at stage 2 of 4 and the program closes
damn i been trying to do this all day
my dvd wont play svcd so kids are well upset cos i cant get the conversion to work
ta people for any info
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32
