I downloaded ffmpegX and the necessary binaries, but when I try to convert a movie trailer I saved (I have QuickTime Pro) or any other QuickTime movie, the resulting file is seen on my PSP as an unsupported data file. I'm assuming that the problem is with one of my binaries, but I'm new at this so I could easily be wrong. Any ideas would be appreciated. Btw, I have a Mac. Thanks.
- Schwim3x6 8)
Results 1 to 15 of 15
I suppose you're using the PSP preset to convert the movie. If yes, email me to major4@mac.com your preset (file > save as preset) immediately before encoding and/or your process output (blue "i" icon in the Progress window).
When my Source is MPG and Target is PSP, I see the following in my Process Output file:
Input #0, mpeg, from '/Users/Dan/Documents/QuickTime‚Ñ¢ movies ?í/Hannah.MPG':
Sat Dec 24 16:18:13 CST 2005
00:00:25.9, start: 0.177778, bitrate: 257 kb/s
Stream #0.0: Audio: mp2, 32000 Hz, mono, 32 kb/s
Stream #0.1: Video: mpeg1video, 160x112, 25.00 fps
Codec type mismatch for mapping #0.0 -> #0.0
When my Source is MP4 and Target is PSP, I see the following in my Process Output file:
Encoding started on Sat Dec 24 16:19:17 CST 2005
Input #0, mov,mp4,m4a,3gp, from '/Users/Dan/Documents/QuickTime‚Ñ¢ movies ?í/Laughter.MP4':
, start: 0.000000, bitrate: 384 kb/s
Stream #0.0: Audio: mpeg4aac, 44100 Hz, stereo
Stream #0.1: Video: mpeg4, 352x288, 30.00 fps
When my source is MOV and Target is PSP, I see the following in my Process Output file:
Input #0, mov,mp4,m4a,3gp, from '/Users/Dan/Documents/QuickTime‚Ñ¢ movies ?í/Trailers/monster_house-tsr_h.640.mov':
Sat Dec 24 16:14:23 CST 2005
Duration: 00:01:52.1, start: 0.000000, bitrate: 1218 kb/s
Stream #0.0: Video: h264, 640x272, 23.98 fps
Stream #0.1: Audio: mpeg4aac, 44100 Hz, stereo
Output #0, mp4, to '/Users/Dan/Documents/QuickTime‚Ñ¢ movies ?í/Trailers/M4V07729.MP4':
Stream #0.0: Video: xvid, 640x272, 24.00 fps, q=3-9, 100 kb/s
Stream #0.1: Audio: aac, 24000 Hz, stereo, 32 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
[h264 @ 0x381324]prefix too large at 0 0
[h264 @ 0x381324]error while decoding MB 0 0
[h264 @ 0x381324]concealing 2147482423 errors
[h264 @ 0x381324]mb_type 55 in P slice to large at 6 0
[h264 @ 0x381324]error while decoding MB 6 0
[h264 @ 0x381324]top block unavailable for requested intra mode at 6 0
[h264 @ 0x381324]top block unavailable for requested intra mode at 7 0
[h264 @ 0x381324]error while decoding MB 7 0
[h264 @ 0x381324]top block unavailable for requested intra4x4 mode -1 at 16 0
[h264 @ 0x381324]error while decoding MB 16 0
[h264 @ 0x381324]top block unavailable for requested intra4x4 mode -1 at 1 0
[h264 @ 0x381324]error while decoding MB 1 0
[h264 @ 0x381324]top block unavailable for requested intra mode at 0 0
[h264 @ 0x381324]cbp too large (117) at 0 0
[h264 @ 0x381324]cbp too large (66) at 0 0
[h264 @ 0x381324]mb_type 36 in P slice to large at 0 0
[h264 @ 0x381324]cbp too large (124) at 0 0
[h264 @ 0x381324]P sub_mb_type 7 out of range at 0 0
[h264 @ 0x381324]top block unavailable for requested intra4x4 mode -1 at 0 0
[h264 @ 0x381324]illegal short term buffer state detected
[h264 @ 0x381324]top block unavailable for requested intra mode at 2 0
[h264 @ 0x381324]error while decoding MB 2 0
[h264 @ 0x381324]mb_type 22066 in P slice to large at 9 0
[h264 @ 0x381324]error while decoding MB 9 0
[h264 @ 0x381324]mb_type 393 in P slice to large at 2 0
[h264 @ 0x381324]P sub_mb_type 34879 out of range at 36 0
[h264 @ 0x381324]error while decoding MB 36 0
[h264 @ 0x381324]left block unavailable for requested intra4x4 mode -1 at 0 0
[h264 @ 0x381324]mb_type 29 in P slice to large at 11 3
[h264 @ 0x381324]error while decoding MB 11 3
[h264 @ 0x381324]left block unavailable for requested intra mode at 0 0
[h264 @ 0x381324]mb_type 26 in P slice to large at 5 0
[h264 @ 0x381324]error while decoding MB 5 0
[h264 @ 0x381324]mb_type 81 in P slice to large at 9 0
[h264 @ 0x381324]top block unavailable for requested intra mode at 31 0
[h264 @ 0x381324]error while decoding MB 31 0
[h264 @ 0x381324]cbp too large (18855) at 8 0
[h264 @ 0x381324]error while decoding MB 8 0
[h264 @ 0x381324]cbp too large (1672) at 39 0
[h264 @ 0x381324]error while decoding MB 39 0
[h264 @ 0x381324]mb_type 66 in P slice to large at 14 0
[h264 @ 0x381324]error while decoding MB 14 0
[h264 @ 0x381324]mb_type 58 in P slice to large at 2 1
[h264 @ 0x381324]error while decoding MB 2 1
video:6507kB audio:0kB global headers:0kB muxing overhead 0.430168%
bench: utime=49.696s
mp4psp: file doesn't exist
mv: rename /Users/Dan/Documents/QuickTime‚Ñ¢ movies ?í/Trailers/M4V07729.MP4.p.mp4 to /Users/Dan/Documents/QuickTime‚Ñ¢ movies ?í/Trailers/M4V07729.MP4: No such file or directory
For the ones that gave "Codec type mismatch for mapping" error, try setting 'Invert mapping' in the Audio tab.
The Monster House trailer is trickier. (1) The aspect ratio isn't 16:9, but 2.35:1, so you'll need to letterbox or crop. (2) Your log shows an output size of 640x272, which is way too much pixels for PSP. (3) You log says output framerate is 24.00 fps, while major's site says Don't change the preset framerate value. (4) You log says video bitrate is 100 kb/s, which should be in the 300-450 range. I got more weirdness when I tried the same file, I don't have a good PSP file yet...
VRO conversion problems
By stellabelch in forum Video ConversionReplies: 3Last Post: 14th Oct 2009, 07:22 -
Conversion problems
By djtommye in forum DVD RippingReplies: 8Last Post: 16th Oct 2008, 03:13 -
VC-1 Conversion Problems
By UHD4096P in forum Blu-ray RippingReplies: 3Last Post: 23rd Aug 2008, 01:40 -
quality problems after conversion
By blubot in forum Video ConversionReplies: 16Last Post: 17th Jun 2008, 11:08 -
film conversion problems
By hobo20212 in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2007, 08:52
