hi, does anyone know how can i compress a RM or RMVB file down (ex:300-->150mb) and adding the sub into it as well
How about Real Producer? If you use such a proprietary format as RM, your choices are limited. Or go to the source of it all, http://www.real.com/. As far as subs, you will have to check there.
so, is there any way to compress an avi file (i'll encode the rm file to avi first and then compress it)
The common way you compress any video file is to lower the bitrate. But lower bitrate=Lower quality. And when you re-encode it you lose quality also. But give it a try. What quality lose you can tolerate is up to you.
As RM is already a highly compacted format, I imagine a fair amount of quality lose if you manage to make it smaller.
Adding subs to real media files
http://forum.doom9.org/showthread.php?s=&threadid=70829 -
Here's some guides for RM to AVI. EO Video is pay, but the others are freeware. I've used EO, but not for that conversion. I wouldn't convert it back to RM unless you really have to. Xvid is probably a better choice or even WMV if you need a small filesize.
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=RM+to+AVI&ho...or+List+Guides
Help to compress large HD File
By camlachie in forum Video ConversionReplies: 10Last Post: 10th May 2009, 13:47 -
compress the .VOB file
By akakiami in forum DVD RippingReplies: 10Last Post: 19th Aug 2008, 08:30 -
compress mpeg file
By bountylord in forum Newbie / General discussionsReplies: 4Last Post: 22nd Feb 2008, 11:33 -
Compress Quicktime File?
By videodirector in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2007, 20:29 -
How Do I Compress a File?
By The Monkees in forum Video ConversionReplies: 3Last Post: 11th May 2007, 18:38
