Hi.
I've searched but can only find how to add srt, sub (text file).
I have a dvd with UK and NL subs (25fps movie) and would like to add the danish subs that i got from another dvd (the subs are in the idx/sub format), but where the picture quality was not that good.
Is it possible to do since they both are at 25fps?
Maybe removing the UK, NL subs so I only have the danish one on it?
Or i must rip the subs to srt first?
If possible how?
Thx
GDK
https://www.videohelp.com/forum/viewtopic.php?p=1427969#1427969
instead of convert the video to mpeg you demux the video from dvd with dvd decrypter and then reauthor with muxman. -
IIRC, there's a resync utility in the VobSub package - there was a thread on that topic about a month ago.
/Mats -
Hi-
I was just playing around with this. I don't think Resynch can do it. At least I can't find any way to adjust the timings of VobSubs when using it. But the Cutter Utility that also comes in the VobSub package can do it. Sort of.
You check the "Modify timestamps to count from start" box and fill in the delay in the start box and save. But it only seems to be able to go one way. You can only make the subs play earlier. If you want them to play later, there's no way to set a negative delay that I can see.
You can also adjust the delay in the IDX file. There's some instructions in there on how to do it, although you may have to experiment to get it right. But after doing it myself and then using Sub2Sup on a delayed IDX file, it didn't keep the changes. So I don't know. Maybe I did something wrong. It works when playing with an AVI, but not when being converted to DVD SUP files. I could be wrong though.
Adding .idx and .sub to .mkv ripped by dvdshrink and handbrake
By theredlaugh in forum DVD RippingReplies: 5Last Post: 17th Dec 2008, 11:11 -
To many IDX & SUB subtitles from DVD...
By locousa in forum SubtitleReplies: 8Last Post: 11th Aug 2008, 08:02 -
How to join the idx/sub languages ripped separatedly into just one idx/sub?
By Talayero in forum SubtitleReplies: 5Last Post: 29th Mar 2008, 08:58 -
avi to dvd with idx/sub
By wingfan in forum Authoring (DVD)Replies: 8Last Post: 28th Feb 2008, 22:17 -
DVD to sub/idx or .sup to sub/idx - How can I do either?
By rock_king_my in forum SubtitleReplies: 4Last Post: 10th Aug 2007, 09:01
