i have pal avi's i need converted which program is best for that?
oh yea and whats the difference btween video clip and movie clip? how do i get to show the extensions on my files i forget
Here's a good, reliable way:
http://www.johnisme.com/
Now, if you mean convert to DVD, do the above and instead of saving a new file, frameserve to MPEG encoder.
Another method is to encode a PAL .avi to NTSC resolution M2V, run DGPulldown, convert audio separately with ffmpegGUI, then author as usual. Again, if DVD is the objective.
Good luck.And if you need a more detailed response, ask a more detailed question.
Pull! Bang! Darn! -
There are quite a few ways to do that, here's a few.
https://www.videohelp.com/convert#4;41
If you look to the left for 'Convert', that's where I found them.
Movie clip or video clip, same thing, just a different name.
In Windows, open any folder, Tools>Folder Options>View; Uncheck 'Hide extensions for known file types.'
Convert 29,976 (NTSC) to 25,000 (Pal) AVI
By volker028 in forum Video ConversionReplies: 5Last Post: 23rd Mar 2012, 02:00 -
Current DVD Recorders in both PAL+NTCS available?
By 1234567 in forum Newbie / General discussionsReplies: 4Last Post: 8th Jan 2010, 17:30 -
Cant convert Pal .AVI to NTSC DVD in Avidemux
By Hittz in forum Video ConversionReplies: 6Last Post: 5th Nov 2009, 07:43 -
how to convert pal avi to ntsc avi ?
By mainone in forum Newbie / General discussionsReplies: 4Last Post: 7th Mar 2008, 11:27 -
Best point at which to Convert?? (NTSC AVI to PAL DVD)
By junk in forum Video ConversionReplies: 3Last Post: 28th Jun 2007, 16:15
