I have 2 xvid files 700mb each i want to join
I've tried about a dozen different joining programs but they all mess up at 1 point or another or cant join an xvid!
Can anybody recommend a good program to join these 2 avi files?
keep in mind ive tried almost every program out there![]()
P.S - i use a very fast computer - 2.8 ghz, 512 ram so the computer is not the problem
VirtualDub can join. If it can't, there's something different between the 2 AVIs (like bitrate, resolution & c.)
Why would you like to join these? For most other reasons than "I just want 1 file rather than two" there are ways to avoid joining.
/Mats -
I tried that
It says "couldnt locate decompressor for format XVid(unknown)"
I want to join them so i can then convert the joint file to dvd format -
Get the latest XviD codec. (Or ffdshow) Without that you wont be able to do anything with your file anyway.
Best is to not join, but encode each AVI to DVD specs mpg, then author with TMPGEnc DVD Author, as 2 parts of the same title. If you remove the chapter point TDA inserts where part 2 starts, it will play as one continous movie.
/Mats
VIDEO_TS to AVI xVid with AC3 5.1 passthrough - problems
By couldtryharder in forum ffmpegX general discussionReplies: 11Last Post: 29th Nov 2011, 09:08 -
Avi(xvid) problems + dvd player
By sgbd in forum Video ConversionReplies: 1Last Post: 20th Nov 2010, 11:53 -
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 08:12 -
Problems burning avi/xvid as data files
By deuceswild13 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jul 2008, 01:49 -
Will joining two AVI files cause problems later in making DVD by Nero 6?
By wayney in forum EditingReplies: 1Last Post: 17th Jun 2007, 20:18
