hello i have 2 .avi files that sum one split from one dvd . i been using divxtodvd to convert. but it seems to do not convert both files to combine then back 2 one files. so can sumone help/tell me a program that can conbine both the .avi files 2 one and one to covert to dvd format so i can burn it to dvd+r... Thanx in advance
DivxToDVD should be able to do that.
But the way I do it is to encode each one separately then put them into a authoring program and let it do the joining. Less sync problems that way.
If you really want to combine them in the AVI format, try Virtualdub. You can also frameserve them from VD after joining to a MPEG-2 encoder like TMPGEnc and not have to create an intermediate file. This saves hard drive space and time. If you look at VD in 'Tools', you can see the frameserving guide. -
Thanx for replyn.. but i downloaded vitualdub but i dont now how to use it to combine those to files...again thanx
File > Open - select your first aviOriginally Posted by grimee1
File > Append Segment
I use virtualdubmod but the principal's the same.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
With the virtualdub method,
What if you get a incorrect bitrate error that requires you to extract the audio seperatley and reencode with a CBR?
This has happened to me many times. Wouldnt it degrade the audio quality by reencodeing it a second time, what if the source is AC3 ?
When you say you encode each part individually wouldnt that make the file too big?
Most transcoders use as much space as possible when converting an avi to vobs. -
Just lower the output size in the converter tool or lower the bitrate instead of joining avis with differen audio.
how do you join two sets of vobs together when they have the same filenames?
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 23:42 -
How do I put AVI files onto a DVD as AVI files?
By dgarmaise in forum Authoring (DVD)Replies: 15Last Post: 17th Mar 2008, 21:32 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
