Hi Gurus,
I am actually recording movies from my Dreambox and, sometimes, archives them on my PC. These files (.ts file) contain a video stream, 2 audio (FR & EN) and one Teletext.
Using VLC (0.8.2), I can easily read them in my PC, switching from one language to another.![]()
But, there is a but... In the VLC subtitle menu, I can select 'Teletext' but nothing appears. Reading the VLC forum, this feature is not supported yet... Fine...![]()
Does somebody know a video player that supports that feature ?
Thanks in advance, great forum !
Foonz
Hi
You can demux dreambox TS by ProjectX.jar ( a powerfull java application )
By ProjectX.jar You can have subtitles file in several format
Use Virtualdubmod to mux
It's not so easy but if You do an hard work You will have wath you like
Write -
foonzoo only had to wait almost two years for a reply to his question.
telxcc (TS teletext subtitles --> SRT extractor)
By petr_ in forum SubtitleReplies: 16Last Post: 16th Jul 2014, 09:31 -
How do I cut TS file and keep Teletext/DVB subtitles ???
By boulder in forum DVB / IPTVReplies: 3Last Post: 30th Aug 2009, 17:50 -
First (?) PAL Teletext subtitle extractor for DVR-MS files
By boulder in forum Latest Video NewsReplies: 21Last Post: 1st Sep 2007, 01:33 -
Ripping PAL Teletext subtitles from a DVR-MS file
By boulder in forum SubtitleReplies: 0Last Post: 8th Aug 2007, 15:23 -
Teletext Subtitles
By voltagex in forum DVB / IPTVReplies: 7Last Post: 1st Jun 2007, 19:36
