I currently have a Yamada Mpeg 4 DVD player, it recently started to have problems playing some divx files, i get the error "QPEL Codec not supported"
I am really due for an upgrade and wanted some advice as to which one to buy.
obviously i have stuff in Xvid and Divx format, as well a DVD's, so i need something that will play just about anything, including the QPEL codec that my current one has problems with.
cheers in advance
Andy
No personal experience with this one (yet), but I've done a lot of research on it and it looks like it does just about everything:
OPPO OPDV971H
http://www.amazon.com/gp/product/B00078GLJY/ref=wl_it_dp/104-7391172-7372718?%5Fencodi...lance&n=172282
-W- -
Hi-
It does play AVIs with Q-PEL, and if all you plan to use it for is AVI playback it'll do fine. If you plan to use it for DVDs also, I wouldn't recommend it unless your TV has either a DVI or an HDMI port or you'll miss out on some of its best features. There are plenty of other DVD/MPEG-4 players with Mediatek chipsets that support Q-PEL and cost much less:
http://www.extremephono.com/Oppo_DV971.htm -
I've been looking for an inexpensive model and the US Logic DP3182 looks awful nice. One of the reasons I'm interested in it is because it plays QPEL. CompUSA has it onsale for ~$45.
http://www.compusa.com/adproducts/product_info.asp?product_code=319618&pfp=ADPRODUCTS -
I also recommend the OPPO. It is also Divx Pro certified...not just Divx certified like many players.
http://www.oppodigital.comGoogle is your Friend
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 02:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 19:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05
