Hi there guys,
MERRY XMAS to you all.
I was wondering if you can help me.
I tried hooking up my new LG RH7500 DVD recorder into my current system.
So i started from scratch, the bottom scart out from Sky Digi (which i know is RGB) goes into AV1 of LG, then loopbacked to bottom scart of TV (which i know is RGB)
But i still get a wishy washy picture. No solid RGB one.
Im wondering if the scarts are faulty - i even tried swapping over the scart connections on the DVD recorder but didnt make a difference.
Just in case you wondering how i know which sockets are RGB for sure, is because i took a scart lead directly from SKY (bottom scart) to TV (bottom scart) and i got a nice solid pic.
Its the DVD loopthrough thats causing the lack of RGB.
(PS this model, has a flick switch labelled PAL\RGB - its in the RGB position at the moment)
Any help would be great!
Results 1 to 1 of 1
Sky+ HD to PC
By BIGD22 in forum DVB / IPTVReplies: 4Last Post: 27th Sep 2011, 14:59 -
recording SKY+HD
By snadge in forum DVB / IPTVReplies: 0Last Post: 26th Feb 2009, 13:15 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 19:02 -
Sky+ to PC
By pjvw in forum Capturing and VCRReplies: 10Last Post: 13th Sep 2007, 13:00 -
Sky HD Box Help
By matw79 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 31st Jul 2007, 15:05
