hi,
sometimes i use a commandline for encoding some files to test some different settings.
using the latest mencoder binaries (i think these for the 0.0.9r and later releases) i get distorted sound while previous mencoder worked fine. I'm able to extract the sound only via the "dump to wav" switch.
did smething in the mencoder settings change?
here's a switch which creates distorted sound:
/Library/Application\ Support/ffmpegX/mencoder -noodml input.file -oac mp3lame -lameopts preset=insane:vol=2 -noskip -skiplimit 0 -mc 0 -vf crop=XXXXX,scale=XXXXX -sws 1 -ovc lavc -lavcopts -vcodec=mpeg4:vbitrate=XXXX:mbd=2:mv0:trell:cbprecmp=2:cmp=2
ubcmp=2:vmax_b_frames=1
redia=2:dia=2
reme=2:vme=5:naq:v4mv
snr -o test.avi
thanks a lot!
Results 1 to 1 of 1
problems installing add'l software for ffmpegX: mencoder
By Tomtom2011 in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2010, 18:47 -
Problems with ffmpegX 0.0.9y and mencoder on MacOSX
By anto1973 in forum ffmpegX general discussionReplies: 11Last Post: 16th Oct 2008, 01:42 -
[RESOLVED] ffmpegx 0.0.9y keeps asking for install of mencoder
By breggol in forum ffmpegX general discussionReplies: 1Last Post: 5th Oct 2008, 05:23 -
mencoder rotates, why not ffmpegX?
By PhilippeP in forum ffmpegX general discussionReplies: 1Last Post: 13th Apr 2008, 16:43 -
No luck with ffmpegX - mencoder segmentation fault.
By jonnymorris in forum MacReplies: 4Last Post: 2nd Mar 2008, 14:07
recmp=2:cmp=2
