I am trying to figure out how to convert an MPEG clip to a DVD format and for the life of me can't find anything anywhere on how best to do it.
Any expert advice as to what program to use would be appreciated.
Thanks,
Vance
If your mpeg is DVD ready then just use TMPGEnc DVD Author (TDA) to author and burn. If it's not dvd ready then TDA will tell you.
"Art is making something out of nothing and selling it." - Frank Zappa -
And if it's not DVD compliant, you will likely have to re-encode it. Check 'What is' DVD to see the DVD specs, then look at 'Convert' for some guides on how to do that. Both to the left. <<<<<<<
Or look in 'Tools' for 'Video Encoders (MPG/DVD)'
I have taken VOB files, demux'ed them to elementary streams ( MV2 and AC3 ) with Vobrator, edited them with Mpeg2schnitt, then imported the edited MV2 and AC3 streams into Ifoedit and used the DVD Author function to create compliant dvds. All the above are freeware.
How to become a computer expert
By freebird73717 in forum Off topicReplies: 7Last Post: 30th Dec 2009, 21:39 -
FLV expert help
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2009, 05:08 -
who is here from uk and is a ripping expert
By lóreal in forum Off topicReplies: 7Last Post: 21st Mar 2008, 19:23 -
Need Major help from an expert!
By jbartosh in forum MediaReplies: 38Last Post: 23rd Oct 2007, 12:45 -
Is this possible? MPC expert please
By ferry1 in forum Software PlayingReplies: 3Last Post: 8th Jun 2007, 18:09
