hi all, happy holidays to those who apply. ok im a newbie, i really need help. i live on a fixed very small income, so i havent upgraded yet to dvd burns, i am still using the 700 meg svcd type burns. i only have one dvd player, and i lost the remote,.. i once burned a movie and it will play automatic-( pop it in the dvd player and it starts right away, dont have to go to a menue and select) since i have no remote and cant find original remote even on line.. can someone help tell me what software program i used to burn it, are what program will burn and when you pop the burned disc into a dvd player it starts rightway, no messing with a menu?? please help, i have several movies i want to burn for the holidays, share with family, thx....
( ps. - i have read and read and still cant find any info how for i am wanting so thats why i am asking, thx)
Results 1 to 9 of 9
Just as a passing thought, I'd consider going into the local video/tv repair shop (id there is still such a thing) and see if they have a box of old remotes. (The shop next to me does) (and they are given away)
Hang on ..... You want US to tell YOU what software YOU used when YOU burned it ?Originally Posted by taterheadtwo
My crystall ball is good, damn good in fact, but that's just asking for miracles
Nero is one possibility, VCDEasy is another. All of the following softwares can also allegedly author VCDs:
https://www.videohelp.com/tools?s=4#4If in doubt, Google it. -
My crystal ball has upgrades so one miracle, coming up.
I think (after correcting for some spelling and grammar) the op means to say:
When I used to make VCD's I just used regular Nero to burn them without menus. I never bothered with my dvd remote, just popped the disk in and hit the play button right on my dvd player and it would just play all the tracks in order. I'm not sure if you can get it to autoplay without hitting any buttons whatsoever though.Originally Posted by taterheadtwo -
He could mean it your way...... do you think we get a cookie if we get the answer right?
I used DVD2SVCD before I had a DVD burner for SVCDs and it autoplayed with my player. But it depends somewhat on your DVD player.
You can probably pick up a low cost universal remote control that might work with your player, but they often won't do as much as the factory remote. Check a few and see if your player is listed on the package.
BTW, When you post here, we appreciate a more descriptive post title. 'im a newbie, help' is not a proper title. Even 'Which SVCD program to use?' would be better.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 08:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 13:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 08:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
MUX Help (newbie)
By thisisjontheman in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2008, 09:52
