I have converted idx/sub subtitles to sup format for authoring in DVDAuthorGUI.
The DVD authors fine but the subtitle's background files the whole screen with either white, gray, black or whatever color I selected when I authored in DVDAuthorGUI!
I even tried using PGCEdit to correct this problem but to no avail!![]()
Anyone have any ideas?
One other thing, here is the info from the idx file:
# Original frame size
# Origin, relative to the upper-left corner, can be overloaded by aligment
org: 0, 0
# Image scaling (hor,ver), origin is at the upper-left corner or at the alignment coord (x, y)
scale: 100%, 100%
# Alpha blending
alpha: 100%
# Smoothing for very blocky images (use OLD for no filtering)
smooth: OFF
# In millisecs
fadein/out: 50, 50
# Force subtitle placement relative to (org.x, org.y)
align: OFF at LEFT TOP
# For correcting non-progressive desync. (in millisecs or hh:mms:ms)
# Note: Not effective in DirectVobSub, use "delay: ... " instead.
time offset: 0
# ON: displays only forced subtitles, OFF: shows everything
forced subs: OFF
# The original palette of the DVD
palette: 6d6d6d, 000000, 6d6d6d, 000000, 7e7e7e, bebebe, 14bef3, ea12eb, faff1a, 000070, 067506, 731f03, 095f78, dadada, 7c950b, ffffff
# Custom colors (transp idxs and the four colors)
custom colors: OFF, tridx: 0000, colors: 000000, 000000, 000000, 000000
Does this help?
dvdsubedit, "You can also change the transparency of the pixels in the subpic."
Thanks for suggestion. Do you know why DVDAuthorGUI would make the background a solid color?Originally Posted by Baldrick
The program does state that color 0 was transparent. -
IMHO it's a problem of pxsup2dast + spumux. That's why I have 'rewritten' this part in GUI for DVDAuthor.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
I confirm that DVDSubEdit can solve your problem...
jeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
Subtitles with a solid blue background
By mew1033 in forum SubtitleReplies: 3Last Post: 17th Feb 2012, 16:28 -
DVD logo with a transparent background
By cobra jet in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2008, 16:31 -
Chroma-Keyed Video with Transparent Background on a Website
By ambassador in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Jun 2008, 22:50 -
Subtitle background is not transparent *solved*
By Meriks in forum SubtitleReplies: 3Last Post: 9th Feb 2008, 16:47 -
I want to create transparent background videos for website
By cctaco in forum Newbie / General discussionsReplies: 2Last Post: 3rd Oct 2007, 17:30
s:ms)
