I was looking on google and found this site which offers motion menu clips,
http://www.dvd-makers.com/products/item44.cfm (you need quicktime for the samples)
How do you create motion backgrounds for use on menus yourself?
I usually use stills, but would love to learn this trick to add a new dimension to my projects...thanks for any and all help
Edit: I guess a follow-up question to this would be what software supports motion backgrounds?
Results 1 to 17 of 17
Sorry for the additional post, but I took a look at that website (from first post).
Sony's website for the Sound Forge and Vegas 6 software also has such video clips that have regular prices (not sale) that are a little cheaper than what you point to. They look remarkably similar.....
http://www.sonymediasoftware.com/visionseries/default.aspWhatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
They're quite easy to make, as all you need is either a still or video, possibly audio, and then go from there. It's no different to creating an MPEG to go on a DVD. Different authoring softwares do it differently however, such as TMPGEnc DVD Author, which requires a DVD-compliant MPEG file with the audio contained within, whereas I'm led to believe that other programs can just take a JPEG still and/or an audio file and do the conversion/muxing for you.
If in doubt, Google it. -
If you want to make simple cycling backdrops, you will need a motion graphics package that supports animation - after effects is a good choice, although it is only one of many.
If you want to incorporate video clips and parts of the movie itself, any editor can do it.Read my blog here.
I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
Thanks,
I was playing around with the "Objects 3-D" plugin in Wax2, when I discovered I could wrap video around a sphere. I always liked the "Crystal Ball" effect, so I thought that this would work nicely for it.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
Dvdauthorgui can create motion menu scripts from titles .
Avisynth , and plugins should be aquired .
For some tricky stuff , the gimp can create png's with alpha channels , handy for creating hightech looking dvd motion menu's .
I have been doing this for quite a while now , both bbmpeg and quenc can encode avs scripts into mpeg2 .
Bbmpeg (aka avi2mpeg) has more settings available for that extra tinkering for required output .
Dosent cost you a cent either ... and is only limited by imagination ... so be creative . -
Here's another one I made using Wax2. I cheated a little on this one, because I used DvdLab Pro to make the Panaramic video clip. I then converted the m2v to avi in Virtualdub and extracted the 1st and last frames. I then edited the last frame in Photoshop (you can use Gimp) and also created the tittle. I imported all asssets into Wax2 and compiled it to what you can see here:
mm.wmv (2 mb)I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
These are very good, Dipstick.
I've been meaning to get into playing with Wax ... you just gave me good reason.
How long did these take you to make?Whatever doesn't kill me, merely ticks me off. (Never again a Sony consumer.) -
That would depend on your skill level.
I'm not an expert with Wax2 by any means, but I'm no novice either. The 1st time creating the 3-D sphere motion menu probably took 15-20 min. If I were to do one now, it would probably be more like 5 min. I pretty much just play with different settings as I go along until I find something I like. Most of the time, I learn something by accident.
If you've ever worked with AE before, Wax2 will come easy, if not, it will take some learning. The best part is it's free, so if you don't mind experimenting, it's worth the effort.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
Excellent job, and nice sliding tackleOriginally Posted by dipstick
Thanks,
Yeah, that's my boy sliding into 2nd base and taking the 2nd Baseman out. Hopefully he learned his lesson and not stand directly on top of 2nd base next time.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
Slow motion videos- how to create some sections
By doggieusa in forum EditingReplies: 3Last Post: 10th Dec 2012, 19:42 -
How to do they Create Motion in this example
By Thread7 in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2012, 16:17 -
How does one create/find graphic and motion avatars?
By PosRole in forum Newbie / General discussionsReplies: 2Last Post: 24th May 2009, 08:32 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11 -
Backgrounds
By boggle in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Jul 2007, 14:35
You can adjust length of motion clip, size etc.
