I just completed a session with WinDV, which of course by default generates multiple AVIs per session that are 2.8 GB a piece.
Ok, fine, but I am trying to convert the clips into MPG2 format but found that TMpgEnc Plus can't deal with more than one AVI at a time.
I know that I can just append them in VirtualDubMod and write out one big file, but this takes time (esp. on the little USB drive I'm using to hold all the files). Isn't there any way of joining the AVIs in TMpgEnc just for the purposes of cranking out the MPEG2 file?
Join them all in VirtualDub then frameserve to TMPGEnc instead of writing the interim file.
Also, for next time, increase the max avi size in WinDV to capsfer all in one."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Frameserving sends the video directly to the encoder without saving, try it. https://www.videohelp.com/virtualdubframeserve.htm
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by timmus
You need to go into the "Environment setting" dialog in TMPGEnc Plus and make sure there's a check-mark at "Open sequence files as a movie". Now, as long as your files are numbered from 00 to whatever (like mymovie.00.avi, etc), it should work.
Jim -
Open sequence as movie -- Thanks, I overlooked that. You're right, it's not checked.
Frameserver: Wow -- that works great! Excellent tip.
Multiple AVIs to a single SD-DVD with MultiAVCHD
By jeffdb27 in forum Authoring (DVD)Replies: 3Last Post: 1st Jun 2012, 15:17 -
Saving multiple AVIs from 1 AVI by virtualdub script
By DveD in forum EditingReplies: 1Last Post: 16th Oct 2009, 08:47 -
Standalone player that can handle 5.1, DTS, untranscoded AVIs?
By buckyboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Nov 2007, 10:22 -
Multiple AVIs to one DVD
By 64RedMustang in forum Authoring (DVD)Replies: 7Last Post: 13th Sep 2007, 18:42 -
multiple AVIs to DVD
By exekutive in forum MacReplies: 2Last Post: 11th Jun 2007, 09:49
