How does 4 : 3 aspect ratio relate to VCD version 2 ?
I capture at 352 x 288 resolution and 1150 kbps rate and PAL 25 fps
But 352 x 288 is not 4 : 3. Same with the capture rate for SVCD
What's the connection?
What if i increased the bitrate of the movie and then recorded it as a VCD what would happen? the bitrate would get cut back to 1150 or will the quality improve?
The quality i get is not very satisfying when seen on my TV. Why? and what can i do about this?
BTW do vcd palyers playback SVCDs by default?
VCD is 4:3. That's the aspect ratio, not the resolution. It just means the pixels aren't square.
What you mean by bitrate, I'm not sure I understand. The VCD standard dictates a (max, some say) bitrate of 1150 kbps, is all. You can well use a higher bitrate, but then it will by definition not be a VCD anymore. If your player will play such a "VCD" depends on how strict it is with standard compliance.
VCD quality isn't good - low VHS quality at best.
Not all VCD players play SVCD (but most).
/Mats -
The pixels aren't square they are rectangular (wide in this case)..Originally Posted by perfection
VCD is a fixed MPeg1 standard.Originally Posted by perfection
https://www.videohelp.com/vcd
VCD is a low quality standard. Image quality improves as you move up in standards. Only VCD and DVD are required to be supported. Individual players may support other standards. Check specs atOriginally Posted by perfection
https://www.videohelp.com/dvdplayersRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
what is FASM Quality Enhancer Bitrate Squeezer??
By u4upendra in forum Video ConversionReplies: 1Last Post: 10th Sep 2011, 11:57 -
Bitrate/QC same file size, is quality the same?
By marioval in forum DVD RippingReplies: 1Last Post: 4th Nov 2010, 09:56 -
Increase the bitrate---> Lose Quality?
By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 14:36 -
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 09:21 -
How do you lower bitrate but maintain quality?
By zanos in forum Video ConversionReplies: 7Last Post: 11th Dec 2008, 01:43
