Hi..I have this problem :
I have acquired from Usa,a box with Earth2 sci-fi series and obviously the audio track is English and the video Ntsc.
I live in Italy,and this box is not available in pal version with italian audio track,but I have the recordings of all episode ,in vhs tape.
Now I have tryied to capture my italian audio from vhs,and re-syncronize this audio with the Ntsc track,without success.
If I syncronize the track to the start of the episode,after 10 min. the syncro is out...
Any idea for help-me ?
Vamp
Extract your audio stream from your Italian capture.
You need to identify two distinct moments at the start and end of the video where sync can easily be matched i.e a close up of lip movement and speech. It's useful to have a program that will let you move through the video stream frame by frame while hearing the audio - Vegas is good for this, but most pro editors will allow this. At this point the audio will not be in sync so you will have to adjust the move the audio stream to make the audio and video in sync for each point separately:
i.e. (where V = video stream, A = audio stream)
The start is in sync but the end is out of sync:
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAA.......
The start is out of sync but the end is in sync:
........AAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
(the audio stream may be longer than the video, but you get the idea
Next you need to stretch/shrink the audio to the exact duration of the video stream between these two points using Goldwave (there's a guide on the forum somewhere) and adjust the pitch accordingly. REMEMBER, THE VIDEO PROPERTIES DO NOT CHANGE - YOU ARE CHANGING THE AUDIO DURATION TO MATCH THE VIDEO.
You will then get a stream like this:
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
You may need to make minute adjustments of one or two frames to get this exact, but since this will be dubbed it probably won't matter.
What you're left with is a video clip with italian audio from the first word to the last. If you want to be fancy, you can then add the opening and ending credits from the original source and get one final clip with music/credits and Italian dialogue
Regards,
Rob -
Thank you very much for yours answers...
I try this methods soon and after I post the results
Regards,Vamp -
Ok friends, work perfectly!
I have used "Magix Video Deluxe 2005" for stretch and resync my Italian track, with the Ntsc video track.
Next I have imported all my tracks into dvdLabpro for authoring... all working fine!
Special thank's to "rhegedus" and "manono" for their precious help. Regards,
Vamp
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Video in PAL and Audio from NTSC source
By jairovital in forum Authoring (DVD)Replies: 30Last Post: 17th Jun 2010, 13:16 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
Syncing Audio CD to Video of Concert (with possible PAL>NTSC conversion)
By ehmjay in forum MacReplies: 3Last Post: 7th Jul 2009, 21:31 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
