  1. can anyone please tell me how to burn data (a 800 mb divx file) on blank 900 mb cdr with Nero???
    Dec 2001
    In front of the keyboard!
    900MB CD-r's???
    Hmmm, Santa did not get me those.. lol
    Seriously, did not know they existed!!?!??!
  3. Assuming that your CD-R/W burner can burn up to the limits of 90 and 99min media, then you burn it like any other CD-ROM.
    I'm not a user of Nero so there may be a version of Nero that you need before it supports the higher capacity media.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  4. As mentioned prevously.... your CDRW drive must support 'OVER-BURN'..... we'll assume it does ! - Nero is probably the best software for this (5+ Versions) Start Nero in the normal way and select FILE/Preferences.... next select the 'EXPERT FEATURES TAB' .... put a 'Tick' in enable Overburn and set the parameters to 99 : 00 : 00 - And thats that! - when you attempt to burn a CDR that is over 80 Mins Long Or exceeds the 700MB in data the overburn function will kick-in and ask you if this is OK...
    Have Fun,
    Paul.
    p.s - I get my 99 MIN CDR's from http://www.121cdr.co.uk
