I used firewire to transfer my DV file using Premiere movie capture. Once encode to MPEG2 and author to DVD, I notice several horizontal bands of noice on fast moving scene. I used my LG DVD recorder to recorder on DVD and there was no such problem. What cause the problem ? Firewire card ?
It sounds like improper encoding of interlaced material, but we need a little better explanation of the problem. How big are these horizontal bands? Can you post a screenshot so we can see it? Almost certainly the firewire card has nothing to do with the problem.
Buy My Books -
Hi gadgetguy,
When I play the DVD on a standalone player, and when there is a fast moving scene, several horizontal bar will flicker acroos the TV screen. -
I think I have found the problem. I took 3 DV tapes during my vacation. Only the first tape is giving such problem. The rest of OK. I use my LG DVD recorder to record from the tape and that fix the problem.
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
Dual band or not?
By yamatosoul in forum Video Streaming DownloadingReplies: 3Last Post: 30th Nov 2009, 17:35 -
Green Band Problem
By fusion99 in forum Blu-ray RippingReplies: 4Last Post: 6th Aug 2009, 11:58 -
green band after using restream
By thecrock in forum Newbie / General discussionsReplies: 0Last Post: 15th Dec 2008, 14:37 -
Band Music Video
By sekthree in forum EditingReplies: 4Last Post: 22nd Sep 2007, 03:21
